A/c Broke!!
Old Aug 15, 2005 | 07:43 PM
LIFER's Avatar
A/c Broke!!
Ok well I had an ac leak cheack done and freon filled and charged and still it does not work. Air comes out just not cold, The guy from the shop said my ac unit was not kicking on. He checked my fuses and relays and everything was fine. Doe anyone have any idea what my problem could be? car has 17k miles on it. Any help on what I should check would be great, ITS HOT OUT!
Old Aug 15, 2005 | 07:48 PM
Deepseadiver's Avatar
Take it to the dealer. I have the same problem and havent taken it in yet. Too far away, and too many mods.
Old Aug 15, 2005 | 09:09 PM
04 rs's Avatar
yea take it to the dealer
Old Aug 15, 2005 | 09:14 PM
import_junkie's Avatar
i'm having the same problem but haven't had a chance to take it into the dealer
Old Aug 15, 2005 | 09:15 PM
evo_rc's Avatar
Most of the time if it doesnt get cold, its the ac fan..... I had this problem with my last car. Just take it to the delearship get it fix for free. If it is the fan, you wouldn't want to buy another fan out of your pocket.
Old Aug 15, 2005 | 09:19 PM
neyugn_naut's Avatar
im having the same prob too.. i want to take it to the dealer but afraid of mods..
what kinds of mods will they take your warrent away for? all mods?
Old Aug 15, 2005 | 10:11 PM
timzcat's Avatar
If you have an 03 it could be fan, related to fan controller.
Also you want to check wiring at compressor and and high/low switches in the lines.
Old Aug 16, 2005 | 07:15 AM
LIFER's Avatar
I would love to take it to the dealer, but I'm sure they will void my warrenty. I have cams, upraded fmic and I/C pipe, as well as small battery, hks ssq bov, and hks stand alone ecu.
Old Aug 16, 2005 | 07:27 AM
ez's Avatar
ez
Absolutely...the pressure switch and wiring is easy to check. You need a 12V automotive test light. If the compressor clutch is not engaging, you would probe for voltage at the compressor clutch, then the clutch relay, etc. to see if the computer is sending a signal or is there is a bad connector/wire...process of elimination....
Similar thing with the pressure switch....make sure it is telling the system to turn on/off the compressor clutch...
Old Aug 16, 2005 | 08:30 AM
LIFER's Avatar
do you think the dealer will work on my car with all my mods?
Old Aug 16, 2005 | 08:34 AM
bechbum82's Avatar
theyll work on it....but will they do the work under warreny i doubt it. so if you do take it to the dealr find out if itll be fixed under warrenty or not. if it isnt then it might be cheaper to take to a private mech.
Old Aug 16, 2005 | 12:34 PM
Mercenary3's Avatar
Id say you have a much better chance of getting your A/C worked on under warranty than say, your TC of something. Remember, its halfway through august. In a month, you wont need it and can wait till next year.
Old Aug 16, 2005 | 02:02 PM
spyderx's Avatar
on a side note, what if the compressor kicks in but still no cold air?
and constantly loosing freon pressure but don't see visible leaks anywhere???
Old Aug 16, 2005 | 02:15 PM
ez's Avatar
ez
Unfortunately, troubleshooting the sealed part of the system usually requires some gear...freon detectors, gages, etc. Some shops will put bright colored dye in the refrigerant to easily see leaks. Some places are not so obvious like the compressor shaft seal or a hidden pinhole leak in the condenser...
bayrider's Avatar
Take it to the dealer. It should still be under warranty.
