cam and camgear question
Old Aug 19, 2005 | 09:58 AM
nongtat's Avatar
Talking cam and camgear question
what set up is the best for power and daily driving and what is the different
do i need to change the cam gear to get more power?
i saw some evo they have the back up fire come out the exhaust just like the sti
when they change the bov and downpipe how does that happen?
someone please help me out i'm looking to change it next month
thx you
Old Aug 20, 2005 | 05:06 PM
jmartinez1170's Avatar
if your egt temp is high u will see the flame come out now thats on stock manifold and 02 houseing if you upgrade thouse it wont shot out flames because it cools down faster that then stock ones i havent shot i flame out ever since i upgraded both on mine.
as far as the cams go just for street use with no ecu missfireing coed poping up 264/272 u will have a good low end and topend will be a lil stronger then stock. i got 280/280 on my car and i have no problem i have not lost any power at low end or topend. but from 5000 and up it just pulls so hard. im on stock cam gears i got a reflash and bumped up the timeing a lil as long time ago so i didnt need to buy them and 5hp is not worth 300 bucks like the guys at AMS and DEVOTUNING say and a few other tuner shops and i take there work over any one elses. i know other people will say diff. so just use your best jugement take care and enjoy your new evo.
Old Aug 21, 2005 | 09:36 AM
Ted B's Avatar
Originally Posted by nongtat
what set up is the best for power and daily driving and what is the different do i need to change the cam gear to get more power?
This depends on which cams you have, which other mods you have, what you are trying to achieve, and of course, your tuning.
The flame is the result of unburned fuel vapor that burns upon contact with oxygen, and it doesn't matter which O2 sensor housing or manifold you're using. Typically this is most evident with cars that do not have a catalytic converter.
Old Aug 21, 2005 | 01:45 PM
nongtat's Avatar
thx alot guy for the answer.
280/280 is it ok to drive? and how many more horsepower do i get above 272/272
with just the stock turbo with 22psi? thx again
Old Aug 21, 2005 | 02:18 PM
Ted B's Avatar
No one can truthfully answer that question (how much hp), simply because it depends on your setup, and if your tuning is suitable for the longer overlap 280 cams.
As for is it ok to drive, the answer is "yes", but like the hp question, it depends on your setup and tuning. A car that is inadequately tuned will not deliver driveability and power as a car with the same setup and better tuning.
Old Aug 21, 2005 | 02:25 PM
smokedmustang's Avatar
I had the 272's for 30K miles set at -2/-2, now have the 280's set at -1/-2, drivability is great, love the lope out the side-pipe also!
