High altitude, long duration cams, and you.
Old Aug 26, 2005 | 10:16 AM
nutrulz's Avatar
I live here in Reno, NV at about 4800' feet, I am planning on getting 272's. Will the altitude make the loopy idle even worse? I will have to wait a bit between getting the 272's installed and flashed, or EMS. Other than power loss, what other problems am I suffering with due to the altitude.
Old Sep 2, 2005 | 11:28 AM
nutrulz's Avatar
Bump
Old Sep 2, 2005 | 11:32 AM
kimletrim's Avatar
Registered User
You shouldn't have any problems with idle at those altitudes other than the same problems you would have at sea level. I know several Evos with those cams at 4500 ft elevation levels without any problems. I have been to the track at thos elevations with 272s and I could not detect any discernable difference in idle.
Old Sep 2, 2005 | 11:33 AM
3240's Avatar
I ran 272's in Denver and didn't have any problems. Besides power loss you'll also experience more turbo lag due to altitude.
Old Sep 2, 2005 | 11:35 AM
nutrulz's Avatar
I hate turbo lag, would 264s be a better choice? My goals are 500whp at sea level.
Old Sep 2, 2005 | 11:46 AM
3240's Avatar
The lag is a result of altitude not cam choice. Again, I had no problem with my 272's.
Old Sep 2, 2005 | 01:55 PM
anjapower's Avatar
loopy idles are crazy
Old Sep 2, 2005 | 04:44 PM
TwStDeVo's Avatar
i was told by someone in denver that 264s are best for high elevation areas. how was your experience with the 272s? also, i will probably PM you about turbo choices for high elevation, i still cannot make my mind up and your the only one that i know who has experience with high elevation and turbos.
Old Sep 3, 2005 | 08:03 AM
Turbo13's Avatar
I have 272's and ran them on the stock turbo and GT3076R, no problems with idle at all. I even run them without cam gears.
Old Sep 3, 2005 | 09:37 AM
TwStDeVo's Avatar
have you been in an evo that has 264s? if so, how does it compare? would 280s be too much?
Old Sep 3, 2005 | 11:08 AM
Turbo13's Avatar
I have been in a car with 264's, obviously not as torquey but much better top end. I might switch to 280's with my new setup, we will see.
v8<turbo4
Jun 9, 2014 08:44 AM
martoony
Oct 17, 2012 11:07 PM
batdorf9
Jul 18, 2011 05:31 PM
Renley
Jan 18, 2011 10:11 AM
Poondoggs
Aug 16, 2010 09:44 AM
