2005 Drivetrain Whining
Old Aug 31, 2005 | 05:59 PM
fullerlee's Avatar
Yeah mine's whiney too, but it's all part of the experience.
Old Aug 31, 2005 | 06:54 PM
Smoothgangsta's Avatar
There was a TSB about drivetrain noise that someone posted. It's a common occurrance so do a search. I also have it on my 2005 Apex Silver EVO with only 1100 babied miles so I know it's a normal.
Old Sep 4, 2005 | 09:34 PM
vtecwrecker's Avatar
my 05 makes the same whine. i hope its normal.
Old Sep 4, 2005 | 09:35 PM
Originally Posted by raf_EVO
Anyone noted any issues during shifting, say from 1-2? I sometimes feel that the gears 'touch' or clash, very so slightly, as sometime you don't depress the clutch fullly... can someone relate to that? It happens only once in a blue moon
mine does the same thing but its on a 2-3 shift. my car only has 300 miles on it so im hopeing it will wear in.
Old Sep 4, 2005 | 09:39 PM
Spec'd's Avatar
Would you 05 guys quit whining about the whine.
Old Sep 8, 2005 | 01:35 PM
Jeller's Avatar
Mine is doing this as well, but its louder than I think it should be.... the whining noise only happens loudly when I am decelerating, it kind of sounds like a throw out bearing is bad, cause it goes away when I push in the clutch.... is this possible? the car only has 700 miles on it. Any one have any experiences with this?
jeller
Old Sep 8, 2005 | 05:54 PM
jeller
the reason it goes away when you push in the clutch peddle is because the gear isnt engaged anymore. now if a rattle goes away when you push it in than you most likly have a bad throw out bearing.
eddy5201314
Dec 4, 2016 06:51 PM
needsboost
Nov 15, 2016 07:23 PM
superkizuna
Oct 20, 2016 12:12 PM
jtcarstens
Apr 7, 2014 01:47 AM
LV///R
22
Aug 15, 2012 09:48 AM
