help needed:weird starting problem
Old Sep 1, 2005 | 03:47 PM
bluebanana23's Avatar
My car has 16,000 miles and is a 03. I went to the dealership to have my car checked out since it had trouble starting. I didn't think it was the battery because it wouldn't crank so I thought it was the starter and we even tried to jump it. When I went to get my car they said everything checked out okay but after I went home and then decided to go somewhere else it wouldn't start. But interesting fact is that every time I open my hood, the car would start normally but if it's closed then it won't. I tested this theory out and works everytime. Any ideas?
Old Sep 1, 2005 | 04:11 PM
bolsen's Avatar
I'd start simple, and check your grounds. Make sure they're tight. Then check the hot side.
Do you have any mods?
Old Sep 1, 2005 | 09:29 PM
i don't know exactly where the grounds are
Old Sep 1, 2005 | 09:33 PM
Deepseadiver's Avatar
Is your hood tuching your battery?? What about popping the hood then starting it? Very strange with the hood. keep digging it is probaly somthing stupid. Did you change anything before it started happing?
Turbolover's Avatar
are ur positive and negative battery cables tight?
Old Sep 1, 2005 | 09:42 PM
nothing has been changed about the battery, it only starts when the hood is popped open
Old Sep 1, 2005 | 10:47 PM
20valves20lbs's Avatar
I have seen something similar to this on a couple other evos......has your airbox ever been taken out???? If so make sure its seated properly on the metal post undrneath and make sure the maf harness isnt binding up anywhere. Hope this helps. Good Luck
Old Sep 3, 2005 | 03:29 PM
Did you find out what was wrong.
aggieEVO
Jul 4, 2016 08:32 PM
Chino051
Feb 1, 2016 02:56 PM
joshS
Jan 20, 2016 09:16 PM
Dkvang920
Dec 12, 2015 09:58 AM
Speed Demon
Lancer Aftermarket Forced Induction Tech
29
May 10, 2002 08:27 AM
