Transmission Oil Question for my MR
Old Sep 2, 2005 | 12:31 PM
Exciting News's Avatar
I just emailed evomoto about their "Diaqueen Super Multi Gear Oil"
to see if the tin has enough oil for a tranny fluid change in my MR. They responded by telling me that it's for the rear diff and t-case and to use Syncroshift for the tranny. Wait a minute!
Isn't "Diaqueen GL5 LSD Oil" for the rear diff and t-case while the Super Multi made specifically for the six speed tranny? If I'm wrong then why would the MR require its own special rear diff and t-case oil when it's mechanically identical to the GSR and RS? I'm trying to stay OEM with my fluids which is why I'm interested.
Old Sep 2, 2005 | 01:37 PM
DaWorstPlaya's Avatar
You're right ... I think they got confused ... too many Diaqueens
Old Oct 14, 2005 | 08:11 AM
mdosu's Avatar
I don't know...but just want to confirm you're "suppose" to use MR Diaqueen in MR tcase and rear diff...that's all I know...everyone else is cool with regular Diaqueen.
Old Oct 14, 2005 | 10:21 AM
Jamie@WORKS's Avatar
DiaQueen Super (GL-4 fluid) is for transmissions and the DiaQueen LSD (GL-5 fluid) is for Rear Diff, but can also be used in the transfer gase
Old Oct 14, 2005 | 10:59 AM
rsboy's Avatar
I think the MR uses a special one Diaqueen Super Multi-Gear oil or something.
I read that it is NOT to be used on the regular Evos but ONLY on the MR.
I used the Diaqueen LSD (gl-5)on my 04GSR, recently, and it's pretty good and highly recommended. I don't think I would change to anything else for the center and rear differentials.
For the trans.. I had the stock oem for about 15K miles, changed to Royal Purple for about 4K miles and now to a Redline concoction my friend made for about 1K miles.. and the car drives near perfect.
Old Oct 18, 2005 | 03:07 PM
MIevo8MR's Avatar
I'm getting close to changing my fluids out. When I do, I'm going to try to take advantage of the free maintainance schedule and have Mitsu reimburse me for the fluids.
If you have an 05, you should've gotten the free maintainance as well.
Old Oct 18, 2005 | 03:19 PM
EFIxMR's Avatar
i changed my mr's fluid with oem at 15k, and it made an improvement in shift quality
Old Oct 18, 2005 | 06:02 PM
rsboy's Avatar
Is the free EvoMR Maintenance Schedule different from the regular Evos? Cause I'm looking at the schedule list I got, it does not state changing diff/transaxle fluids at all. They inspect it and make sure the levels are good, but does not state about replacing the fluids except the engine oil and filter.
Too bad you can't use the Diaqueen GL-5 Gear Oil I use, you know I would have hooked you up!
Old Oct 19, 2005 | 01:11 PM
MIevo8MR's Avatar
I thought it said replace, but not 100% sure. I'll check when I leave work tonight.
Old Oct 20, 2005 | 08:14 AM
MIevo8MR's Avatar
Yeah, it says change.
Old Oct 21, 2005 | 08:33 AM
rsboy's Avatar
Damn... pre-05s get shafted ...yet again!
Old Oct 21, 2005 | 11:43 AM
fsugatorbait's Avatar
Not all 05's have the free maintenance though.
Old Oct 21, 2005 | 12:08 PM
rsboy's Avatar
really? that sucks.
we'll my 04 came with the free maintenance, but not like the one MIevo8MR listed. It's pretty much just free oil changes and inspections. Model year close-outs specials, I guess.
Old Oct 21, 2005 | 01:25 PM
dan628's Avatar
my dealer screwed my on the free mainteneance, he said it was for all cars except EVO... what an a$$hole....
EvoMoto
14
Jan 12, 2006 06:00 PM
EvoMoto
Evo 'For Sale' Exterior Styling
48
Oct 25, 2005 12:30 PM
BADEVO
26
Oct 10, 2005 07:32 AM
EvoMoto
84
Aug 23, 2005 09:54 AM
EvoMoto
Evo 'For Sale' Miscellaneous
Apr 22, 2005 02:16 PM
