Sheet Metal Intake on Staock Turbo
Old Oct 6, 2005 | 01:35 PM
BADEVO's Avatar
Sheet Metal Intake on Stock Turbo???
http://www.evomoto.com/product_info....d3a454a945d013
Do you guys think adding this to a car with the factory turbo is worth it?
I have 272 Cams, Cam Gears, Intake, 3" Turbo back, Catless, Hard Pipes, 10.5 Hotside, Tubular Exh Mani, Tubular 02 housing, ALKY Kit and Using ECU+ for tuning.
Old Oct 6, 2005 | 01:44 PM
dan628's Avatar
honestly there are better brands out there, If you got the money go for it, but I would shop around a little first....
Old Oct 6, 2005 | 01:51 PM
BADEVO's Avatar
.... such as... that doesnt give me a whole lot to go with.
Old Oct 6, 2005 | 01:56 PM
ap-evo83's Avatar
From: RAMAR village, pampanga PHILIPPINES, Temecula, CA
^^^magnus, rnr
Old Oct 6, 2005 | 01:59 PM
BADEVO's Avatar
Just looked at the Magnus....... looking for rnr link now
This is why I pose questions on here...different points of view.
Thank You
Old Oct 6, 2005 | 02:16 PM
fixem2's Avatar
Check with Buschur regarding his Ported Intake and Throttle Body combo.
Old Oct 6, 2005 | 02:18 PM
evoego's Avatar
Registered User
sounds interesting
Old Oct 6, 2005 | 02:20 PM
BADEVO's Avatar
Looked at his site, but I cant take the car apart and wait for replacement parts.
Old Oct 6, 2005 | 02:23 PM
NDgsx's Avatar
Also look at AMS.
Old Oct 6, 2005 | 02:34 PM
BADEVO's Avatar
Originally Posted by NDgsx
Also look at AMS.
The AMS VSR intake manifold is a must for any evo with an aftermarket turbo, allowing for strong clean pulls to 9500+ rpm on race engines.
Old Oct 8, 2005 | 03:22 PM
Z1 Performance's Avatar
I would not bother with this on a stock turbo car....a royal PIA to install (regardless of the brand), and lots of extra tuning required afterwards...and anyone who tells you otherwise is trying to sell you something.
I've seen more than one Magnus blown apart as well.....not what I would recommend to anyone
Old Oct 8, 2005 | 05:49 PM
AWDrift07's Avatar
Many of the aftermarket intake manifolds don't retain any of the emission controls. thats the only neg i can think of as far as on a street car: not being able to pass emissions. is the idle affected by an aftermarket manifold? would it be necessary/ beneficial run a stand alone ems?
sorry for high jacking but i'm curious also.
Old Oct 8, 2005 | 05:56 PM
NDgsx's Avatar
Most people that are seriously looking at one have enough mods to where they are already running a standalone.
The only way I would run one on a stock turbo is if I was doing track days running lower boost and just wanted a huge powerband to reduce shifts. That would be the last thing I'd be doing though.
Old Oct 8, 2005 | 06:00 PM
badlooser's Avatar
the stock manifold gives you the best bottom end torque if you are looking for top end then it is worth it.
Old Oct 8, 2005 | 07:26 PM
MalibuJack's Avatar
I am typically "Critical" of products offered by Weapon-R, but this is the first one that impressed me enough to consider it.
Not so much that its a sheet metal intake, it basically looked identical to the other aftermarket intake manifolds out there, but its specifically available in a version that retains the stock sensors, vacuum lines, and other stock pieces that are required for the factory ECU to not complain..
If the quality of the metal and welds is good, and the fit is good, then I don't see anything wrong with trying it. Heck I'd try one out if I had a few extra dollars or could get one for evaluation.
