BPR8EIX or BR8EIX?
Old Sep 2, 2005 | 01:41 PM
k270kmh's Avatar
Question BPR8EIX or BR8EIX?
I need to go one step colder...
Which one Do you recommend?
Thanks
Old Sep 2, 2005 | 01:49 PM
kmcconn9's Avatar
I know I have seen a bunch of threads on this one...just search..I believe that one will last longer...im not positive though, I am running the bpr7es...just have to change them more frequently than the platinum or irridum
Old Sep 2, 2005 | 01:58 PM
Kwman's Avatar
I preffer the copper based BR8ES plugs. Better spark, they just wear out faster. Also DO NOT GAP the iridium plugs if you get them. And BTW, one step colder than stock would be the 7s.
Old Sep 2, 2005 | 02:03 PM
k270kmh's Avatar
Stock Plugs are 7.
I did a research and found mixed results...
Old Sep 2, 2005 | 02:08 PM
PVD04's Avatar
The stock plugs are 7s, one step colder would be 8s. If you don't believe me go pull the plugs out of your car and look model number. I've been using BR8ES for ~7000 miles and they've been great, although they do have to be changed more often than the iridiums. I'll probably end up going back to 7s for winter as it gets pretty cold here and I think cold start could be an issue with the 8s.
-Paul
Old Sep 2, 2005 | 02:28 PM
k270kmh's Avatar
I read good reviews about BR8ES cooper.
Anyway I prefer the iridium ones since I do not want to change the plugs more often.
I read good/bad things about Denso IW24
I read good/bad things about the HKS S40G that is supposed to be made by Denso.
B= 14mm thread diameter
P= Projected insulator type
R= Resistor type
7= Heat range. Higher numbers are colder
E= 19mm thread reach (?)
ES= standard 2.5mm center electrode
IX= Iridium
To go or not with a projecte insulator type...
Old Nov 12, 2005 | 06:03 AM
TomasDXB's Avatar
Thumbs up Br8eix
Pls see the condition on my original (stock) NGK Iridium plugs after 34,500km. I was expecting much worse than this. Could I have your valueable feedback pls? Thx.
I have replaced the stockers with BR8EIX and so far very pleasing behaviour. I even did an autox event and no problemo what so ever...
Would highly recommend guys...a lot of milage out iridium plugs as you can see.
Tom
Attached Thumbnails BPR8EIX or BR8EIX?-spark-plugs-after-34-000km-006-resize.jpg
slipperychicken
Feb 27, 2016 10:27 AM
heel2toe
47
Apr 20, 2013 03:33 PM
pinoy6969
Pacific Northwest
Jul 27, 2012 12:53 PM
catman78
Nov 21, 2010 01:10 PM
neonhero
Jun 17, 2004 02:14 PM
