Velocity of gas going thru the upper IC piping
Originally Posted by SlowCar
the reason i am asking the question is to see where the best place to place my water injection nozzle. was deciding either immediately after the IC or the UPIC. with all the info from you guys, i think i will put it immediately after the IC
I mounted my Aquamist nozzle at the end of my stock UIP. It works great! See the attachment pic below. I don't advise that you place the nozzle before the diverter valve tube or the water mixture will be recirculated back into the turbo. I found that out when I had my BOV vented to the atmosphere on my Talon. When you let off the gas after a full throttle run, water was all over the engine. I E-Mailed Richard at Aquamist a while back and he advised me the bend in the UIP will actually help the water mixing with the air due to the speed diiferential between the outside and the inside of the bend. A small swirl will be generated near that area.
Originally Posted by Ted B
Peak velocity of airflow through the upper IC pipe occurs at the point of peak hp.
Originally Posted by Shaun@SG
I believe the point is not peak HP, but peak RPM. The engine may be inefficiently trying to pull and inefficiently using the air at that RPM (hence tapering torque/power), but volumetric flow is still the highest at that point.
But let me toss in one little 'monkey wrench'...
What I said just above applies to a normally aspirated engine. With a turbo engine, the hp/tq curves alone may not tell the entire story with respect to Ve and flow. Why? Because a large turbo that spools late may not reach full boost until after the engine's Ve max, so the torque curve may not reflect the actual Ve.
Additionally, a smaller turbo may not reflect the actual point of peak flow in a hp graph because the turbo may run out of steam before point at which Ve begins to drop at a faster rate than the rpm increases. So, the actual air velocity as measured in the IC pipes (which is a product of air volume) may increase somewhat beyond the point at which the MAF begins registering a decrease in air mass (hp).
Peak flow occurs at peak hp, because hp is essentially a function of Ve (torque) with respect to rpm. Above the rpm at which peak hp occurs, Ve is dropping off faster than the rpm increases.
That is the simplified version ...
The system is always considered as a whole.. the NA peak charging efficiency point of a TC engine does not need to be found in isolation because the TC engine will never be run NA.
Maybe, but the efficiency characteristics of the N/A mechanical assembly is important because it allows us to make appropriate decisions with regard to cams, cam timing, etc.
Apologies for how short these posts are and for perhaps not being warm or polite.. it's not that I feel that way, it's just I haven't slept for a long time this weekend. I just now realized the tone might be off, after re-reading posts and noting the progression.
FWIW, I have a very difficult time believing that an $800+ water injection kit is going to equal, much less beat the proven results of the $500 methanol injection kits used by a good few EVOs (including my own). Just FYI.
Oh yes, what a tragedy. Aaron Broussard's public plea was heart wrenching. Everyone please watch the video link off http://www.overspun.com/?p=1549 as well as read what the people have to say below in the comments. Makes me so sad and angry.
Hope your loved ones are ok Ted. I can't imagine what it is like to be working in one of those insurance companies right now. They're probably going to be backed up for years.
[WTB] Thru the hood o2 dump
Remmz
Oct 24, 2015 07:37 PM
JUS4SHO
11
Jun 29, 2015 01:47 PM
