My ACT story (not good) - please read
Old Sep 3, 2005 | 01:11 PM
  #31
11secEVO7's Avatar
told u so....
I did my 11.3 pass using the ACT...No issues at all!
then all of a sudden a month later....high rpm lock out!
ACT should really do something about this......it cant be a coincidence that nearly everyone is having this problem
Old Sep 3, 2005 | 01:42 PM
  #32
showbo's Avatar
My buddy has the Clutchmasters Stage 3 clutch, and he gets locked out of 1st-2nd gear shift too. Its pretty lame. But if he shifts @ 6k...its just fine
Oscar
Old Sep 3, 2005 | 01:45 PM
  #33
SlyEvo's Avatar
hmmmm... good thing im going for exedy. good luck with everything warrtalon, and everyone in the same boat..
Old Sep 3, 2005 | 02:16 PM
  #34
MattGold's Avatar
God I love my Twin Exedy... 1.6 60' times, and consistent 11.6-11.8 @ 118-120...
Its hard to convey what a difference an awesome clutch makes - because everyone's first question is "well, how much power does it hold?"...
Trust me - working for Exedy or not... the Twin is the best clutch on the market for the Evo VIII...
Old Sep 3, 2005 | 02:54 PM
  #35
11secEVO7's Avatar
yeah honestly...a twin disc is the best investment..
i know the ACT is affordable...but in the long run twin discs are great..
excellent pedal feel....and they withstand high rpm launches lovely
Old Sep 3, 2005 | 07:52 PM
  #36
TD05HR's Avatar
i also have an ACT for about 8 months now..i get lock out anything pass 7200...so far ive learn to live w. it and shift @ 7000..plus i get the rpm rise w. this clutch which is the most annoying thing imho...ACK!!!
Old Sep 3, 2005 | 07:55 PM
  #37
DSMotorsport's Avatar
Originally Posted by 11secEVO7
told u so....
I woudln't nearly say "EVERYONE" is having this problem. I have 16k miles on my ACT with no trouble. Once it was adjusted after the first week of use, it has been consistent. Made over 100 drag passes with it, mostly 12.2 to 11.5's. I make my shifts wot, and extremely rarely miss a gear. The engagement point has started to creep higher up, indicating that I might have worn through the disk already. If so, Ill gladly stick a fresh disk in there and be done.
Old Sep 3, 2005 | 08:09 PM
  #38
Evoryder's Avatar
here's what i would do b4 you go buying clutches and trannies...
1. change tranny oil ...redline mt90, royal purple ...etc..change transfer case fluid too
2. adjust clutch pedal...did you do that after you installed the act? ...a lot of the time missed gears are due to the clutch pedal not being fully depressed ...might want to do that ...so that you can lower your friction point for quick shifts and what not
Old Sep 3, 2005 | 08:10 PM
  #39
Spec'd's Avatar
Originally Posted by DynoFlash
The bottom line is that the ACT street style clutch is way too heavy and has a terrible disnengagment. The puck style racing units they sell are much better shifting but IMHO the street style set up just wears the crap out of your syncros.
The japanese twin disc clutches are more money but they are vastly superior in shifft speed and feel.
Keep in mind for those who dont know Exedy makes the OEM clutch, supplies ACT with the clutch cover which it uses for its clutch which is a modified exedy pressure plate and makes a whole range of clutch offerings for the aftermarket.
Al or someone knowledgeable,
Would this be a good clutch for a daily driver ?
http://www.coximport.com/store/EX05803
I like the feel of the stock clutch, I just want something quality.
I'm not a drag racer. I enjoy twisty roads.
Old Sep 3, 2005 | 08:55 PM
  #40
DynoFlash's Avatar
That would be very similar to a act but with a lightter pedal pressure
The twin dick is the one I really like
Old Sep 3, 2005 | 09:19 PM
  #41
Warrtalon's Avatar
HAHAHAHA, that's one for the archives. No disrespect, Al!
Old Sep 3, 2005 | 09:21 PM
  #42
EvoTio's Avatar
^^ I didn't notice that at first .
Old Sep 3, 2005 | 10:08 PM
  #43
Warrtalon's Avatar
Originally Posted by awdmofo
that's gonna end up on someone's sig for sure, just wait til the vishnu fans read it
I'd put it in my sig, but I have nothing against Al. It really is hilarious, though, and should be archived in the annals of lore (no, I didn't say "****," haha)...
Old Sep 3, 2005 | 10:12 PM
  #44
EvlEvo8's Avatar
I have an ACT CLutch on a stock Flywheel. I SOMETIMES get locked out but get good 60 foots times on 30PSI street tires netting me 1.79 or so. Sometimes I can run down teh track real fast no iddues, somethimes it is VERY hard to get in gear.
If it wasn't these shops RAPING ME on the install, I would be getting a new clucth. I mean it's $1000 including the ACT, the Exeddy is like what well over $1,000 I mean people simply can not afford this stuff. I like my act, works as advertised and will support 500 FP's of torque and got me through my DSM days. It may not be perfect but damnit I can afford it.
Old Sep 3, 2005 | 10:36 PM
  #45
Erik@MIL.SPEC's Avatar
Seriously, I'm looking at the keyboard trying to figure out Al's simple mistake, but the "s" is on the opposite side of where "c" is (in relation to "d"). In other words, s and c aren't next to each other like r & t. Hmmm
