My ACT story (not good) - please read
My car has total 19k miles ...
* ACT Street clutch with 5k miles
* Pedal adjustment feels totally fine
* Stock lines and fluids
* TSB done on 5th gear grind
I get 2nd gear lookout even on the street when shifting above 7k rpms but did notice if I shift at 7k rpms and take 1/2 sec more to shift it goes in very smoothly. But I cannot speed shift at all.
I don't know if the new steel shifter bushings and stronger motor mounts from Buschur would make any difference.
Originally Posted by EvilDylan
i have the EXACT smae problems with my ACT, that i had with my stock clutch.
there is NOTHING wrong with the ACT, i guarantee it.
inertia: Resistance or disinclination to motion, action, or change: the inertia of an entrenched bureaucracy.
Doesnt matter the clutch manufacturer, at 7000+RPM the inertia that is created by a ~20lb. rotating assembly with an 11" overall diameter creates a HUGE amount of wear and tear on synchros, fluids, and everything associated with continous lightning-fast shifting.
There really isnt just a one time fix for maintaining a system that will perform without flaw every day, it is a constant battle.
dru
dru
You can't guarantee it, Dylan. I had _0_ problems with my stock clutch and never once got locked out. In fact, it's the first time I've experienced such a thing in my entire life in any car, which includes 3 DSMs, all of which had previous versions of the ACT (2100 and 2600). It's possible that it's not my ACT, but the fact that so many have the EXACT same lockout problem indicates that it's very possibly the ACT. Like I said, there's no way you can guarantee anything, because you're just one example. On the other hand, you could be right, too. I'm not condemning the ACT yet, but I will see what happens after I do the aforementioned things to see if I can speedshift again: pedal adjustment, SS clutch line, and restrictor removal.
thing is im not one example. There are many others who have had the exact same problem with the stock clutch. Do a search on it, and you will find out. Why do you think there are TSB's on the transmission? Because there are synchro problems, most likely the cause of your lockout problem.
dru
dru
For a daily driver with no lauching or racing, what would you choose
between the ACT single organic vs Exedy ACT single organic ?
From what I've read Exedy makes the clutches for ACT and others.
a good way to find out whats going on is get the pp, clutch disc, and flywheel measurement specs from ACT, and compare to what your production ACT's specs are. I wouldn't be surprised if the disc was too thick and causing your disengagement problems.
but on the other hand, i been around a lot of drag racing... and it really tears up your tranny. Even with a twin disc clutch, the overall shift quality deteriorates when you quartermile your car.
Originally Posted by Spec'd
Dru,
For a single disc setup, the ACT has always held up to some good abuse.
dru
same problem still
Exedy doesnt make the clutches, they supply components that are remanufactured by ACT to their own design and specifications.
dru
dru
