First gear not hitting 19...help?
Old Sep 3, 2005 | 01:13 PM
turtlelancer's Avatar
Anyone kno why im not hitting 19?... i got a turboback and intake besides the boost gauge... I hit 19 in everyother gear... i went for a drive just now to check again and i saw 19 like once or twice but everyother times i wouldnt reach 19 id hit like 13psi. my other gears see 19
Old Sep 3, 2005 | 01:35 PM
SilverEvo8owner's Avatar
i never hit full boost in first gear. There isnt enough load to build boost fast enough.
Old Sep 3, 2005 | 01:36 PM
showbo's Avatar
Umm dude...since 1st gear goes by so fast, you shouldn't NEVER see 19psi unless u got af fuly built race motor and is tuned for it. Its very normal to not see you peak boost in 1st gear, than in 4th.
A MBC is usually set in either 3rd-5th gear...I set it in 4th gear. So that being said. I don't see 19psi in 1st or 2nd, because the gears go by so fast, 3rd-5th is 19 though.
So don't worry its normal.
Oscar
Old Sep 3, 2005 | 01:47 PM
oh ok.... someone gave me misleading info then.... they said i was suppose to hit 19 in every gear... i was liek damn i dont.. Thanks oscar and silverevo
Old Sep 3, 2005 | 01:54 PM
Warrtalon's Avatar
Next time, do a quick search, and you'll probably see the exact issue you have mentioned many times. This particular issue has been discussed probably hundreds of times. You never hit as much boost in 1st or 2nd as you do in later gears, which is why we all tune our boost controllers in 3rd or 4th...
Old Sep 3, 2005 | 02:00 PM
ev08buoy's Avatar
I have a boost guage with a hallman set lowest possible (off).
From time to time I seen my boost guage hit 20-24 PSI from 2nd to 3rd or 3rd to 4th.
Untuned, is that not normal.. I don't want to blow anything.
Old Sep 3, 2005 | 02:08 PM
Warrtalon's Avatar
Tuning has nothing to do with your MBC.
If you have the Hallman set lowest possible, you would not see anything higher than 11 psi, so this leads me to believe you have no idea where your MBC is set, or you have it installed backwards. Btw, don't jack threads...
Old Sep 3, 2005 | 02:11 PM
I did search but thanks warrtalon
Ralliart87
Oct 25, 2011 04:22 PM
bigjhoney
19
Nov 12, 2005 06:20 PM
bigjhoney
11
Sep 5, 2005 11:30 AM
jmartinez1170
Midwest Region
78
Jun 27, 2005 12:20 PM
vietxscapeD
West Region
28
Nov 4, 2004 11:54 PM
