downpipe w/ stock cat PROBLEM?!!?
Old Sep 4, 2005 | 09:54 PM
go2evo's Avatar
Question downpipe w/ stock cat PROBLEM?!!?
when getting a 3 inch downpipe, do i have to get a high flow cat or stock cat works too? please help!!! thx
Old Sep 4, 2005 | 10:00 PM
ev08buoy's Avatar
the stock cat is no good for any aftermarket downpipe.
Old Sep 4, 2005 | 10:04 PM
turtlelancer's Avatar
umm.... i dont kno what he is saying but you can use ur stock cat its just you wont get as much power as an aftermarket one......
Old Sep 4, 2005 | 10:05 PM
go2evo's Avatar
so is it worth it to just get the downpipe without the hi flow cat?
Old Sep 4, 2005 | 10:11 PM
its all up to you, and what ever your goals are... IF you really want the most out of ur exhaust get a test pipe if not just go with a high flow cat, A high flow will let you pass emissions but you wont get as much gain as a test pipe or if you want a minor gain a downpipe is still good. I put my downpipe in a couple days before my tp and i felt a difference already.
Old Sep 4, 2005 | 10:13 PM
go2evo's Avatar
so with stock cat and a 3" downpipe, you felt the difference? huge difference?
Old Sep 4, 2005 | 10:15 PM
go2evo's Avatar
and which downpipe you are using?
Old Sep 4, 2005 | 10:16 PM
better response, and slightly faster turbo spool
fromWRXtoEVO's Avatar
Well I don't know if it is worth to keep a 3" Downpipe with a stock cat but I know for a fact that the flages on the stock cat bolts on just about any aftermarket Downpipe and /or cat back.
On my opinion, do it right and get either a 3" test pipe or a 3" cat, some companies have them really cheap like Logicperformance.
Old Sep 4, 2005 | 10:17 PM
invidia downpipe
Old Sep 4, 2005 | 10:21 PM
go2evo's Avatar
thank you for your guys feedback!
Old Sep 4, 2005 | 10:31 PM
rlazer5000's Avatar
A 3" downpipe is definitely worth it. You would be creating a bottleneck with the stock cat in place, so I would recommend a high-flow cat/testpipe, depending on emissions of course. I have an Apexi GT downpipe and I had it bolted up to my stock cat for a little while. Pretty much any downpipe will bolt-up to the stock cat because they all use the same flanges.
Old Sep 4, 2005 | 10:38 PM
brooks1005's Avatar
If you get a test pipe,make sure you do one of the two OBDII cheats.Either the mechanical fix or the electronic fix.I have a Helix dp and testpipe with the mechanical fix.It took about thirty minutes to put the cat back and remove the OBDII fix to pass my yearly emission test.
Old Sep 4, 2005 | 10:57 PM
evileye's Avatar
hey i have a brand new ams test pipe sitting in my room not being used for sale 3" stainless steel. i live in cali also
