EGT probe breaking?!!!!
Old Sep 5, 2005 | 07:18 PM
ICE888's Avatar
Okay folks,
My EGT probe just broke inside my manifold. How I noticed? Well I was accelrating normally then there was a sudden hesistation followed by the car slowing down a lttle. Look over at my EGT guage to find no reading. Pulled car over and didnt notice anything obvious. Went and drove home right away. Notice car a little slower pickup but nothing too dramatic. Car still held boost fine. Got home, took off EGT probe to find it BROKEN! I am pretty sure my turbo is toasted. I am going to take apart my turbo to try and retreive it but I am sure the blades are all bents or nicked. I am just disappointed in how it broke. It was an Apexi ELII EGT guage probe. Has anyone else has this problem before? Do you think APEXI will cover it under warrenty or am I on my own. I didnt EVER expect an EGT probe to break! Oh well.
Thanks for hearing me rant!
Alfred
Old Sep 5, 2005 | 07:33 PM
SlowCar's Avatar
the conditions in the exhaust is harsh....rich(soot), lean, sudden heating....the soot forms on the surface of the 304SS/inconel sheath of the thermocouple from the combustion + the 800-900C heating drives the formation of carbides. heating, cooling, vibration will eventually cause the TC to fall apart..............not too much you can do.
Old Sep 6, 2005 | 01:52 AM
Rcebowl's Avatar
WHOA are you serious?! this a normal problem???
Old Sep 6, 2005 | 02:11 AM
marksae's Avatar
How many miles do you have on your probe? On my 1g DSM, my greddy EGT probe broke after 2 years and ~30k miles, mostly highway. EGT probes should be a maintenance item.
Old Sep 6, 2005 | 09:51 AM
ICE888's Avatar
Less than 500 miles. It was brand new. Brought from the Apexi sale earlier this year.
I am very disappointed.
Alfred
Old Sep 6, 2005 | 12:09 PM
Rcebowl's Avatar
wow this does happen alot???
anyone esle have this problem???
Old Sep 6, 2005 | 06:00 PM
SlowCar's Avatar
buy a type K t/c replacement from omega.com. Just measure the length of the sheath, specify inconel/grounded....and armored leads.....IIRC...its ~$50
Old Sep 16, 2005 | 06:30 AM
outsider's Avatar
This topic has got me curious... does anyone have more info on this? Is this a common occurence for EGT probes to fail?
Old Sep 16, 2005 | 06:35 AM
edwin's Avatar
i dont know much other ppl, but my is almost as well. getting new one before that happen.
Old Sep 16, 2005 | 06:45 AM
ibanez_926's Avatar
i think TRE sells one that is stronger
i may be wrong tho
Old Sep 16, 2005 | 06:49 AM
maverick92482's Avatar
wow dont want to hear this. i was planning on putting an egt in my car
Old Sep 16, 2005 | 07:28 AM
bolsen's Avatar
All the more reason why I should buy a better probe...
Old Sep 16, 2005 | 05:38 PM
SlowCar's Avatar
the best you can buy are inconel grounded......w/o resorting to exotics like platinum or iridium..
Old Sep 16, 2005 | 05:47 PM
zyounker's Avatar
This is fairly common.. I am from the RX7 world with higher EGTs then the evo and it is a common occurance.. We always tap the EGT in the downpipe about 3 inches from the turbine.
Your readings are a little low, but you don't have to worry about damaging your turbine wheel.
Old Sep 16, 2005 | 05:55 PM
SlowCar's Avatar
I guess the thing to do is to use 2 T/C, one in the mani, one in the downpipe. Measure the 2 and see the difference, then remove and plug up the hole in the manifold.
