changing exhaust manifold... gaskets?
Old Sep 9, 2005 | 07:49 PM
SoR's Avatar
SoR
I have an extra stock exhaust manifold which I drilled for EGT and I'm looking to get it ported/coated. Do I need to change the gaskets after I remove the original one?
I'm thinking the one to engine block and another one to O2 housing but is it really necessary?
Thanks
Old Sep 10, 2005 | 05:46 PM
SoR's Avatar
SoR
bump
Old Sep 10, 2005 | 09:40 PM
Zeus's Avatar
I've reused them successfully a few times, however, if you can replace, why not?
Old Sep 10, 2005 | 09:42 PM
carbonevo8's Avatar
i reused the stocker for my JIC header and no leakes still 6000 miles later runs great changed it with about 8000 miles
Old Sep 10, 2005 | 09:45 PM
evopower1021's Avatar
gaskets aren't that expensive, why not change it if you can.
on the other hand, if its not broken don't fix it, or change it
Old Sep 10, 2005 | 09:56 PM
Nad1370's Avatar
You can re-use metal gaskets as long as it's not damaged. Jusk make sure the mating surfaces are clean and flat.
Old Sep 11, 2005 | 06:59 AM
SoR's Avatar
SoR
Thanks!
Old Sep 22, 2005 | 02:17 PM
Tom Sawyer's Avatar
Gaskets are so cheap, for the peace of mind I just use new ones.
Tom
Old Sep 22, 2005 | 03:03 PM
Zeus's Avatar
I agree, but I've reused mine on my own test mule at least a half dozen times without fail... and I don't bother using a torque wrench on my car.
Old Sep 22, 2005 | 03:16 PM
Deepseadiver's Avatar
I love it! I used the old gasket and I have a small leak. Think of how much work it was, or how long it took to do the mod. That should give you your answer on weather to replace gaskets or not. I couldent get a torque wrench to all of the exhaust mani bolts.
Old Sep 22, 2005 | 04:13 PM
Nad1370's Avatar
Lol...me too.
I use German torque specs.
Evo47
Mar 10, 2016 10:27 AM
yellowbirds58
MitsubishiParts.net - WA
Apr 13, 2010 02:09 PM
Carloverx
11
May 22, 2009 09:16 AM
QwikEVO
Nov 3, 2006 06:04 PM
