FPR altering on stock evo?
Old Sep 9, 2005 | 11:07 PM
MrMejia's Avatar
Okay so heres a question. I looked everywhere for this specifically but to no avail for my situation. Technicaly if you raise the fuel pressure slightly higher than stock levels (5-10psi more) and your injectors work in the area of 80% duty cycle then you should get better atomization and better combustion hence more power. correct? I'm guessing that the stock 550cc injectors on the evo work lower than 80% duty cycle when at WOT (80% being the general rule of thumb for ideal) so If I raise the pressure just a tad. It could give me an edge on a stock evo? what do you guys think?
oh yes, just to let you all know I'm basically still stock looking to mess with a little better fuel tune later after I get my full eghaust system beefed up with a flash.
Old Sep 10, 2005 | 08:31 AM
MrMejia's Avatar
ideas? questions? answers?
Old Sep 10, 2005 | 07:55 PM
MrMejia's Avatar
bump for some insight...
Old Sep 11, 2005 | 05:57 AM
Ted B's Avatar
Originally Posted by MrMejia
Technicaly if you raise the fuel pressure slightly higher than stock levels (5-10psi more) and your injectors work in the area of 80% duty cycle then you should get better atomization and better combustion hence more power. correct? ... so If I raise the pressure just a tad. It could give me an edge on a stock evo?
No and no.
Injectors are designed to give best atomization at a certain pressure differential, and that differential is maintained by the FPR. This has nothing to do with duty cycle.
Raising fuel pressure slightly results in no performance advantage. The ECU detects the slightly rich condition in closed loop operation and compensates its fuel trims accordingly to correct it.
rhyzin
Lancer Aftermarket Forced Induction Tech
26
Sep 22, 2012 04:29 PM
timzcat
41
Jul 8, 2010 04:57 PM
94AWDcoupe
Apr 30, 2009 03:38 PM
David Buschur
74
Jan 17, 2007 07:09 AM
Bosshog
Oct 28, 2006 05:16 PM
