Cams without tuning
Old Sep 16, 2005 | 10:17 AM
nutrulz's Avatar
Cams without tuning
So I have a new set of 272s I'd like to put in this weekend. My mods are as follows:
K&N Filter
Works P2 Flash
TBE
Forge RS BOV
I will not be able to be tuned for a while, perhaps I'll wait till I get AEM EMS. What are the effects of cams without tuning specifically for the 272s? I know the obvious one is funky idle. That I can live with. But what about AFR's or anything else? I live in Reno, so altitude is about 4800 ft. and gas is wonderful 91 oct. So what should I do?
Old Sep 16, 2005 | 10:19 AM
RyanM's Avatar
Which 272s? HKS?
Nez136's Avatar
You'll need to tune, im pretty sure you would run lean, without tuning it wouldn't be worth it to install
Old Sep 16, 2005 | 10:21 AM
nutrulz's Avatar
HKS, yes.
Old Sep 16, 2005 | 10:25 AM
RyanM's Avatar
Your AFR will be off, but it will run--I don't think you'd run lean though. Get a reflash from Works.
Old Sep 16, 2005 | 10:31 AM
nutrulz's Avatar
I'd like to get a reflash, but I can't be without my car for 3 days.
Old Sep 16, 2005 | 10:46 AM
EVO_8's Avatar
I've been running on HKS 272s for 3 months without a tune, but I also installed a Walbro fuel pump at the same time. Still can't decide if I want an AEM EMS or Dynoflash.
I'm not sure what my AFR is, but I don't hear any knock and the car runs great.
Old Sep 16, 2005 | 05:36 PM
evosorio's Avatar
It should not be lean, on the contrary, it should be rich, since the ecu will add more fuel because it will receive a lot more air. It'l run, not as good as tuned, but just ok
Old Sep 16, 2005 | 09:30 PM
ctx2000's Avatar
if you need just for daily driver, go with ECUTEK or DYNOFLASH.
Old Sep 16, 2005 | 09:35 PM
Wicked's Avatar
I've had the HKS 272's installed for 7 months now, and i'm untuned.. also debating the AFC/EMS/Flash dillema.. You'll be fine, but it does run super rich, under WOT pulls you can see smoke (w/a catless TBE).
Old Sep 17, 2005 | 06:14 AM
KTT's Avatar
KTT
272's
I too have HKS 272's without a tune. The car runs rich, I'll be getting a custom Dynoflash in a month but for now I'm happy... I raised the idle to a little over 1k rpm... still lopey but it pulls hard to redline
Old Sep 17, 2005 | 07:55 PM
EVO_8's Avatar
If you would set the cam geras I -4, E -1, you wouldn't have to raise the idle.
Mine idles like stock (850 rpm), can't tell the cams are in.
Old Sep 17, 2005 | 08:12 PM
evojon's Avatar
Put em in and enjoy the idleing sound of power on tap, it won't hurt a thing.
Cams are cool!
Old Sep 18, 2005 | 04:45 AM
rghli's Avatar
i am thinking about the cams too. if i mostly daily drive plus one or two autocross events each month, which cam i should have? reflash or safc2?
Old Sep 18, 2005 | 05:24 AM
SterlingEvo's Avatar
Due to scheduling conflicts, I ran for over a month with HKS 272s set at 0,0 without at tune (I was previously flashed for other stuff). When I went to finally get tuned, I was told by Al that my car was actually running pretty well, and that it only needed a few minor tweaks. In other words, it certainly isn't BEST to run it untuned, but it shouldn't be a problem as long as you eventually do it. You'll be happy when you do get tuned (or standalone, or whatever)...
By the way, I asked this same question to a lot of people before I did it, and people really scared me into thinking I had to IMMEDIATELY get tuned, but that wasn't the case for me...
