Dynotuned at BR.....
Old Sep 18, 2005 | 05:43 PM
GOKOU's Avatar
Well went to BR for a dyno flash tune with the alky kit this past Friday.
All the guys at BR were friendly, helpful, and top notch . Would recommend them to anyone.
Not sure what the numbers will equate
to on a dynojet or other mustang dyno since BR dyno reads low but final number was 304 hp, 301 tq. I believe A/F was at 11 and boost at 25 psi. Maybe boost could of been higher and A\F leaner but I wanted to be safe. Car feels great and pull strong. My mod is bascially BR S4 with alky kit. I was previous dynoflashed and all I added was the alky kit using denature alcohol and 93 octane gas..
I'm not sure but there might be something wrong with the baseline run or with my car (bov, exhaust leak) in case you guys were comparing. I'll let you guys decide whether this is low or not.
http://tinypic.com/drce9d.jpg
Old Sep 18, 2005 | 08:57 PM
awddyno's Avatar
what was wrong with the car. looks like it fell on its face after 5500rpm.
did it drop boost or ???(baseline graph)
I've seen this torque with pump gas and around 22psi peak boost.
Old Sep 18, 2005 | 09:05 PM
GOKOU's Avatar
JUst got clarification and it looks like the baseline run was with the alky kit on (tested) and no tune so it was running rich.
Just curious but was the number you saw on a MD? FRom what I hear BR seems to be low but accurate. Car runs great. I hope I can make it to the track soon. I just need to get the ACT clutch lock-out fix first. Planning to run like it was dyno with full weight, spare tire,etc
Thanks.
Old Sep 18, 2005 | 09:21 PM
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
I don't think on the BR dyno. Different dynos= different whp #s.
Old Sep 19, 2005 | 07:02 AM
GOKOU's Avatar
I agree and that's why I was more concern about the before and after numbers but in my case not sure if I can really tell the difference but I'm guessing 30,30 .
Old Sep 19, 2005 | 07:51 AM
That looks about right, but I would say it is much more than that at redline, maybe close to 60,60 or more. It is just hard to say with you before.
Old Sep 19, 2005 | 08:13 AM
justchil's Avatar
Were you the last tune? Silver subi? I feel like an asshat now for not talking to ya.
Add around 15% to get dynojet numbers. Curve looks pretty nice
Old Sep 19, 2005 | 08:25 AM
gsujeff55's Avatar
wtf you guys talkin about 30,30 and 60,60?? did i miss something in the thread?
Old Sep 19, 2005 | 08:33 AM
GOKOU's Avatar
We were talking about the increase in HP\Tq of the baseline vs the final numbers
Old Sep 19, 2005 | 08:39 AM
GOKOU's Avatar
Sorry that wasn't me. I was the first one tuned on Friday. But yeah you should have talked to silver subi. I had a great conversation with XXX. Forgot his user name in here.
15%?? So that means my final number is about 350 Hp\340 TQ on a dyno jet?? COuld be but strange. There could be something wrong with my car then cause I think other cars with similar mods be posting numbers higher then me Or It also could be that dyno varies Also I was suprise to see HP and TQ being about the same. From dyno charts that I saw with alky usually one is higher then the other. In any case I'm a happy customer
Old Sep 19, 2005 | 08:48 AM
Doogie Howser's Avatar
3625 pounds? Does that seem kind of high? Really good numbers on BR dyno.
Old Sep 19, 2005 | 10:26 AM
justchil's Avatar
15% is just a general number.. depending on who you ask you will get anywhere from 10-20%. I don't think there is any 100% accurate way of determining it.. but I'm not that worried about it.
Old Sep 20, 2005 | 01:48 AM
David Buschur's Avatar
Doing some comparisons from our old 2wd Dynojet to our new AWD MD, there is very close to an 18% difference.
The 3625 and 15.1 HP @50 mph are the settings that Mustang supplies for the car. To keep things even we use the same settings on each car. I am guessing they derived their numbers for a car plus 1-2 passengers. We have messed with this number and haven't found any difference in the tune of the car and the HP numbers don't change much either.
David Buschur
www.buschurracing.com
Old Sep 20, 2005 | 10:34 AM
ny-quiL's Avatar
me = XXX
your car pulled some real nice numbers. nice to mee ya
scheides
Aug 31, 2009 04:34 AM
scheides
Jun 19, 2009 05:50 AM
StreetThisEvo
Jun 13, 2009 06:09 PM
David Buschur
302
Aug 2, 2008 03:28 AM
David Buschur
40
Jun 2, 2008 12:37 PM
