buschur racing cat back fit ?
Old Sep 22, 2005 | 07:34 PM
kondo's Avatar
I just installed a buschur 3 inch cat back and dp with high flow. It sounds really good but the tip seems like it sticks out too far. At least 1 inch past the stock. The straight pipe is going inside the cat; how far is it supposed to slide in? Can someone who has installed one tell me if its supposed to stick out that far.
Thanks
Nick
Old Sep 22, 2005 | 07:40 PM
BoostWhore's Avatar
make sure your rear muffler is shoved un all the way. Typically they stick out more than stock it helps to keep the black build up off your bumper
Old Sep 22, 2005 | 07:56 PM
wingnut's Avatar
I have the opposite problem with my SCCA catback. It doesn't stick out far enough. I can probably adjust it but I think the tip would be too close to the bumper then. I'll just wipe the carbon off every now and then.
Old Sep 22, 2005 | 10:35 PM
awddyno's Avatar
its a slip type exhaust system, make sure the muffler part slips over the long mid pipe and the high flow cat over the mid pipe a good almost 2" each. I've installed many of these and all came out perfect. Done tighten anything until you have it where you want it. should look stock.
Old Sep 23, 2005 | 05:49 AM
EvoWrxowner's Avatar
Thumbs up
Just re-aligned mine this past weekend. Loosen the clamp around the slip fitting, make sure the muffler is aligned with the mid-pipe and tap the muffler tip with a rubber mallet. It will line up with rear bumper. Mine had stuck out about 2". Looks great now.
Thanks
Nick
Old Sep 23, 2005 | 06:31 AM
mike1023's Avatar
which buschur 3in did you get like high flow cat or del and magnaflow or offroad
Old Sep 23, 2005 | 06:47 AM
si_eater's Avatar
+1 ^^
i have the buchur 3 inch tbe w\cat del and reg buschur muffler real loud and its perfect not to far out or in and no black soot on my bumper
Old Sep 23, 2005 | 06:49 AM
mike1023's Avatar
can any of you with the buchur 3in full turbo back make a video of a take off and a drive by at wot
Old Sep 23, 2005 | 12:36 PM
kondo's Avatar
I pushed the pipe into the muffler and now it fits perfectly. Thanks for your help everybody!
Nick
Old Sep 23, 2005 | 12:40 PM
Jrod@Buschur's Avatar
Nick
I just seen this thread.....I guess i'm a day late and a dollar short. Glad your happy with your purchase. If you need anything else let us know. Thanks
Jarrod
Buschur Racing Inc.
blkdrgn09
Jul 2, 2014 06:23 PM
FloopyDisk
Sep 9, 2007 01:21 PM
slt
15
Jun 17, 2005 01:10 PM
BushBurninEvo
17
Jan 15, 2005 01:10 PM
evodave
Aug 20, 2004 03:44 PM
