Installed MBC and have backfire problems.
Old Sep 24, 2005 | 08:29 AM
dbdude's Avatar
I just installed a hallman pro mbc. Not the RX. I turned it 3 turns out and im reading about 14-15 psi at full throttle. My 03 evo has HKS rs intake and a TBE with high flow cat. Not tuned yet. When i try to go full throtltle in the lower gears, the car bogs and jerks big time. In the higher gears like 4-5 it wont do it, maybe just one little boom out of the exhaust. What can this be? Is it too lean? Will a wallbro fuelpump and a flash dynotune solve this?
Old Sep 24, 2005 | 08:42 AM
krafty's Avatar
I doubt it, sounds like different issue. I ran my mbc at 21 psi w/o my walbro and tune for a while, no problems....
Old Sep 24, 2005 | 08:56 AM
dbdude's Avatar
Do you think it can be fuel cut from the ECU?
Old Sep 24, 2005 | 09:32 AM
dbdude's Avatar
Anyone else want to put an opinion please?
Old Sep 24, 2005 | 10:23 AM
eclpsgsx97's Avatar
If anything, you're proably running too rich. Stock boost and stock fuel maps are very conservative and run rich in the first place. Isn't stock boost around 19 psi, anyway? Maybe at 14 psi WOT, too much fuel causing backfires in low gears. Higher gears, more load, bit higher boost, leaner mix, less backfire.
Old Sep 24, 2005 | 01:32 PM
dbdude's Avatar
Stock boost on my meter is 10-11psi. OK does more air mean leaner or richer? I think it would be leaner but i may be wrong.
Old Sep 24, 2005 | 04:38 PM
eclpsgsx97's Avatar
More air for a given amount of fuel is a leaner mixture. As for stock boost, I don't know, I drive a 2G DSM. But my brother's evo is stock, and I remember his being around 18. 10 or 11 seems pretty low.
Old Sep 24, 2005 | 07:17 PM
evopower1021's Avatar
stock boost is about 19 lbs. it is pretty low only running 14-15lbs try turning up your boost atleast to stock and see how that works for you
Old Sep 25, 2005 | 09:20 AM
dbdude's Avatar
If stock boost is about 19psi then im definatly getting a wrong boost reading. I will try to get a better reading by switching the T to the fuel pressuer line. Now that i think about it, I might be trying to boost way past 20psi and im probably getting fuel cut.
Old Sep 25, 2005 | 11:33 AM
2jzEVO's Avatar
for me it's sound cool
galantman03
43
Feb 5, 2017 09:54 PM
dierr
11
Jul 3, 2014 09:18 PM
wazmunstr
Jun 28, 2014 05:54 AM
AdamWest
May 3, 2011 08:15 PM
PorkRoll
May 25, 2007 06:57 AM
