P0420 code?
Old Sep 26, 2005 | 10:46 AM
dbdude's Avatar
P0420 code?
This mourning i got this code. Autozone printed out a receipt that says- The PCM has determined that the catalyst system efficiency for bank 1 is below threshold. Bank 1 means cylinder#1. Any ideas or help would be greatly apreciated. Thanks. I have a highflow cat, i dont know if this has anything to do with it?
Old Sep 26, 2005 | 10:55 AM
dbdude's Avatar
bump.
Old Sep 26, 2005 | 11:00 AM
FlameRed05SRT's Avatar
Well I know SRT-4's are different from EVO's, but on an SRT-4 the P0420 code is Catalyst 1/1 efficiency below required level. Hope that helps.
Old Sep 26, 2005 | 11:02 AM
gsujeff55's Avatar
uh, bank 1 doesn't necesseraly mean cylinder 1, especially when talking about the catylist system. Has something to do with your hi flow cat im sure.
Old Sep 26, 2005 | 11:03 AM
dbdude's Avatar
So could this mean my highflow cat is not as good as a stock cat? Not cleaning the gases enough before leaving the cat?
Jacoby's Avatar
I thought the 420 code meant it is time to smoke..
Old Sep 26, 2005 | 11:06 AM
number 8's Avatar
Bob Marley CD time. BTW, its the hi-flow cat.
Old Sep 26, 2005 | 11:07 AM
gsujeff55's Avatar
That too, its your car telling you that you are driving too fast....smoke a doob and you'll slow down for sure, probably run 45 in a 55...LOL
na, seriously, its saying your cat isn't working properly(according to stock cat specs). Your hi-flow cat is doing exactly what you bought it to do, be less resrictive.
look in the how-to section to find out the mecanical fix for your rear o2 sensor. its a simple fix, and you won't get a cel.
Old Sep 26, 2005 | 11:08 AM
Smike's Avatar
P0420 - Catalyst System Efficiency Below Threshold (Bank 1): Indicates Bank 1 catalyst system efficiency is below the acceptable threshold.
Possible Causes:
· Malfunctioning ECT/CHT
· High fuel pressure
· Damaged exhaust manifold
· Cylinder misfiring
· HO2S wiring concerns (shorted or chafed, bent pins, etc.)
· Damaged exhaust system pipe
· Damaged muffler/tailpipe assembly
· Retarded spark timing
Damaged Catalytic Converter:
· Use of leaded fuel
· Oil contamination/consumption
· Silicone contamination (sealants/cleaners)
From: http://www.v8sho.com/SHO/TSB0197HO2SServiceTips.htm
My guess is that your High Flow Cat is causing the computer to think that you have a damaged cat and is throwing the code. My suggestion is to do the mechanical 02 fix, found in the how-to section. Or to get the 02 simulator.
Old Sep 26, 2005 | 11:13 AM
ibanez_926's Avatar
Old Sep 26, 2005 | 11:17 AM
Evoryder's Avatar
just get an 02 simulator and call it a day
Old Sep 26, 2005 | 11:21 AM
dbdude's Avatar
WOW, Thanks for the replys. Keepem coming. I know a couple of you guys run test pipes. Do yall get this code?
gsujeff55's Avatar
http://www.forums.evolutionm.net/showthread.php?t=98573
mechanical o2 fix. works like a charm, and no cuttin and splicing wires like an o2 simulator. total cost is less than $3
Old Sep 26, 2005 | 11:22 AM
gsujeff55's Avatar
i got the code, even with a o2 simulator installed...this prompted me to do the mechanical fix and i haven't had a code since.
Old Sep 26, 2005 | 11:51 AM
dbdude's Avatar
If i do the fix, will I still pass emissions?
