Little bit in insight on drivetrain problems
Asta4125, can you post the different shifting techniques you use with AWD, RWD, and FWD? This is my first AWD car and I have had it, trouble free, for 11,000 miles. I shift the same way I would any other car but you say I shouldn't.
Launching is obviously different with the available traction in an AWD car but how is shifting different?
To hard and long for me to explain driving techniquesof RWD, FWD, and AWD. Im sure there is plenty of infro out there. Or maybe someone else can relate.
Originally Posted by Asta4125
For sure...your facts are correct, however since the evo has a longer or taller first gear it would mean that it would take more power and torque to break the tires free. This still does not answer all the people blowing up diffs, rear ends, and t-cases.
Taller first gear makes it harder to break the tires free. Much wider tires stock than the 1G DSM's makes it harder to break the tires free. Much stickier tire compound stock than 1G DSM's makes it harder to break the tires free. Add all that additional traction up, and add a third more power than a stock DSM and you start doing "side step the clutch" launches and you end up with broken drive train parts. People taking advice from old school DSM guys are more likely to break drive train parts in a stock EVO.... they are totally different animals to launch.
Keith
Originally Posted by evodave
it starts to whine loud when the ring and pinion is off and going to wear wrong. Mine is from horrible abuse...but still needed work before i broke it. Once i broke the diff i had to end the use of the Tcase for that time cause if i cut the wheel hard and went forward it would almost lock the outer wheel and clunk so bad. It was the teeth that broke off. The car also became almost rwd.
-Dave
The tallon gearing in the evo makes a giant differance to how aggressive you have to be in the evo8 vs DSM.
I know both cars pretty well, my talon went 10.0 @ 147, evo8 goes 11.5 @ 120.
The evo needs far more aggression, rpm, and clutch slip on the line to not bog. And with 17" wheels, you don't have alot of traction, so it's a fine line between bogging and smoking the tires.
I think the drivetrain is alot better in evo8's than dsm, as 1gs have rear axles break, center diffs break often in the high to mid 11's. I do have to favor the dsm clutch though, this pull-tob setup on the evo8 is stupid. Weight of the car also put s a big hurt on the clutch.
Originally Posted by eve-slow
When I am turning a corner very slowly (especially when I'm getting in to 1st), I am having a clunking and metal on metal noise? Does not happen in reverse, or at any decent speeds. Mostly happens when I'm pulling out of a parking spot with the wheel fully cranked to either side. Also, doesn't happen so much when the car is cold? Wierd huh?
-Dave
-Dave
I did eventually break parts, however it was after doing doughnuts for 3 min straight in a dry parking lot...so my fault. In realtion from the dsm to the evo. yes the evo has taller gearing. But i will tell you after luanching the talon...and my buddies 11 sec evo. i would have to say it is much easier to launch the evo for some reason. But as far as it goes with everyone breaking drivetrain parts, i cant conclude that taller gearing, and sticky tires are to blame. Im sure it has something to do with it but not at 15k on your car.
Originally Posted by ez
I wouldn't say wierd. Your CV joints are shot....very common on cars with halfshafts...
-Dave
-Dave
Originally Posted by Fourdoor
It may not be like starting in 2nd, but it is very noticable. At 7500 RPM in 1st in a DSM you are running 36.7 mph. An EVO at the same RPM is running 42.9 mph. A 6.2 mph difference is huge, and it makes a large difference in launching.
Keith
Keith
Originally Posted by elhalisf
who told you that? 1g dsm's are 26mph for 1st and 34mph for the galant vr-4
Keith
EVO9SK
10
Feb 12, 2020 01:27 AM
eastxcelerate
14
Oct 18, 2010 12:18 PM
1g, common, drivetrain, dsm, eclipse, evo, facts, fwd, insight, issues, launching, mitsubishi, problems, traction, understand
