Valve Cover vent hole??
Old Sep 28, 2005 | 07:28 PM
992gnt's Avatar
Need some help here. Just tonight I noticed that there is a small brass fitting in the valve cover. This fitting is on the back side of the valve cover, right behind the #1 cylinder, just above the bottom lip. It's actually in very close proximity to the crank angle sensor plug.
The fitting is round and has a hole in the center of it. It looks like something should fit into it (little rubber plug maybe?), but the hole is small - maybe 1/8". Is something supposed to be in there? Maybe from the inside? Oil is slowly seeping from this hole on my car, down the block, and I don't know why. The valve cover has been off a few times lately, but I have no idea what the hole is for. Can anyone enlighten me????
Old Sep 28, 2005 | 07:58 PM
Nad1370's Avatar
PCV valve.
Hose must have fall off. Goes back in the intake manifold.
Old Sep 28, 2005 | 07:59 PM
992gnt's Avatar
No, not the pcv valve. I know what that is. This is below and to the left of the pvc valve. There is no nipple on it, just a hole into the valve cover.
Old Sep 28, 2005 | 08:01 PM
Compjoc's Avatar
is it just by the the # 1 cylinder spark plug boot?
Old Sep 28, 2005 | 08:09 PM
Quickshifter's Avatar
this might not help at all but u wouldnt be happening to hear any high pitched wines at idle do you?
Old Sep 28, 2005 | 08:13 PM
992gnt's Avatar
No unsual noises. It's not on the top of the valve cover, it's on the back side of it. You have to lean over the engine and look down to see it. The hole faces the firewall.
Old Sep 28, 2005 | 08:17 PM
timzcat's Avatar
Drain hole.
The other end is inside where number one cylinder is. It is there so if you spill oil or get water in the spark plug area it can drain out the back of the valve cover.
Old Sep 28, 2005 | 08:18 PM
Nad1370's Avatar
Saw it...
No plug. Just a brass fitting with a hole in it. Stuck a toothpick in it and goes in pretty deep.
No leaks here though. No idea what it's for.
Old Sep 28, 2005 | 08:24 PM
992gnt's Avatar
Originally Posted by timzcat
Drain hole.
That makes sense. I'll pop the spark plug cover off and make sure nothing is amiss. I did have one of the spark plug hole gaskets get mis-aligned a while ago that leaked some oil into the plug area. Hopefully it's just leftover oil from that. Thanks!
Tsensational
Jul 27, 2016 08:53 PM
plan:b
Dec 25, 2015 09:07 AM
hibby
Sep 25, 2010 01:10 PM
Sti THIS
Dec 11, 2006 06:08 PM
Ninj0x
Aug 17, 2005 08:38 PM
