23psi spike, should I be worried?
Old Sep 29, 2005 | 12:56 AM
Scoot's Avatar
So I installed my Hallman ES boost controller today and every gear except for 5th spikes up no higher than 21psi then goes to 20psi. 5th gear spikes to 23psi for a second then drops to 20psi, according to my Defi D boost gauge. Should I be concerned about this or can I let it slide and be okay?
Old Sep 29, 2005 | 01:00 AM
vboy425's Avatar
you're fine don't worry
Old Sep 29, 2005 | 01:31 AM
NTHECRUX's Avatar
enjoy the boost your fine
Old Sep 29, 2005 | 01:42 AM
Rcebowl's Avatar
shouldnt it matter on what oct your running?
Old Sep 29, 2005 | 02:08 AM
2GDSM's Avatar
I think everyone here is assuming he's running premium.
Old Sep 29, 2005 | 02:13 AM
CoolGuyWes's Avatar
Yeah but he's in CA... so its only 91oct.
Old Sep 29, 2005 | 06:36 AM
Scoot's Avatar
Yeah, running 91oct, getting a custom dynoflash in about a week when Al comes out here. Just want to know if anyone else has similar spiking issues.
Old Sep 29, 2005 | 06:45 AM
evo0486t's Avatar
yea u good... i got a turbo xs high performance BC .... and its not flashed just like yours and mine spikes up 24-25 and then drops down to 20,21,22... but ur fine.. no need to worry...!
Old Sep 29, 2005 | 08:07 AM
EvoWrxowner's Avatar
Boost Spike
I have same exact setup on 93 octane and experience same spike you are in 5th.
But I am not worried. Tried a slight adjustment down but then you drop to 19PSI and it still spikes. Could be lack of back pressure from running a 3'' exhaust system.
deadbeatrec's Avatar
im holding at 1.5 bar or 21.75psi. and i have boosted 1.7 bar b4 for i think ur fine.
Old Sep 29, 2005 | 10:04 AM
dan628's Avatar
I have the stock exhaust and it does the same thing....
Old Sep 29, 2005 | 10:09 AM
Warrtalon's Avatar
That's way too high. The thread originator is fine, but you are not...nor is deadbeatrec or whatever. There's no reason to run that much boost on pump gas, for it only causes you to knock heavily.
Old Sep 29, 2005 | 10:15 AM
bluebanana23's Avatar
on a hot day my car spiked to 26.3 psi, my car is still fine but this was on 93 octane
Old Sep 29, 2005 | 03:22 PM
evo0486t's Avatar
like i said .. its bein doin it for over 5 months .. and car is still fine.. i didnt say it holds that amount of boost.. i said its spikes for like 2 seconds and then comes back down .. in 5th gear by redline it holds 21 or 22 .. i know im good..!!!
Old Sep 29, 2005 | 03:29 PM
djmikeymike's Avatar
this is why i got rid of the MBC and went with the EBC..........no spikes and no taper
