To much boost?
Old Sep 30, 2005 | 04:02 PM
GootBoost's Avatar
Question To much boost?
Ok I have a question I have a 05 evo and I just put a greddy rs bov, injen intake, and my vdo boost gauge. Ok everything is working perfectly except my boost my gauge is reading 27lbs and then bleeds back to 22lbs. This doesn't seem right, now my gauge has been sitting in my basement for a while it came off a previous 1.8t gti and when removed it worked perfectly. Any input or ideas?
Old Sep 30, 2005 | 04:25 PM
whiteghost's Avatar
any boost control on the vehicle (flash or mbc/ebc)?
Old Sep 30, 2005 | 04:31 PM
bolsen's Avatar
what does it read at idle?
Old Sep 30, 2005 | 04:38 PM
EVOL EDO's Avatar
what does it read in vaccuum also
Old Sep 30, 2005 | 05:38 PM
thebluesky's Avatar
did you bypass the boost solenoid completely, and do you have a full or partial exhaust setup?? Or, by chance, are you using a boost controller of some sort?? If you answer yes to either of these questions, then that's your problem. If no, then your boost gauge is probably not reading accurately anymore.
my .02.
Old Sep 30, 2005 | 05:44 PM
SiCKlEyWiKeD's Avatar
sounds about right, the stock turbo can't hold that much boost so it's gonna taper a lot!
Old Sep 30, 2005 | 07:38 PM
GootBoost's Avatar
No I am not using a boost controller and I don't have a downpipe or cat back no mods have been done aside from what has been listed. At a idle the car is reading 0 boost and then when you start to pull off it gradually increases once you mash the gas it shoots up almost right away.
Old Sep 30, 2005 | 07:41 PM
GootBoost's Avatar
my .02.
I didn't bypass it I hooked it up as such.
Old Sep 30, 2005 | 07:44 PM
gsujeff55's Avatar
it reads 0 at idle? its waaaay wrong.
should read around 15vac at idle without cams.
Old Sep 30, 2005 | 07:54 PM
GootBoost's Avatar
looks like I may need a new gauge huh.
Old Sep 30, 2005 | 08:04 PM
superflyevo's Avatar
try splicing it with the vacume line that goes to the bov
Old Sep 30, 2005 | 08:06 PM
evotino's Avatar
Make sure it reads vac. Some gauges only read positive pressure.
Old Sep 30, 2005 | 08:14 PM
GootBoost's Avatar
My gauge reads both it the one in the pic below.
Old Sep 30, 2005 | 08:16 PM
GootBoost's Avatar
Thats how I hooked it up in my previous vw but I was following numerious peoples instructions on how to on the evo's
Old Sep 30, 2005 | 08:27 PM
althemean's Avatar
0 PSI at idle is totally off. should be around 10 inhg +-2 inhg
