My newest ACT story (good)
I'll give timeslip details in the Drag Racing forum, but I felt obligated to provide these results from tonight's trip to the dragstrip as they pertain to the ACT HDSS itself.
- Made 5 passes
- Missed one shift, which was the 4-5 and was not a lockout, but merely driver error
- Nailed best 60' ever (1.66)
- Made every other shift with razorlike precision, including no-lifts on the 3-4
- Shifting was so smooth that I didn't once have to THINK about shifting...this is how it was back on the stock clutch when I was running 12.2s
- Hit personal best 1/8th et, 1/8th mph, 1/4 et, and 1/4mph
The ACT performed admirably tonight - it met every expectation I had when I bought it. The only change since my disastrous trip to the track a few weeks ago is that I adjusted the pedal from 4 threads to 2 threads remaining on the rod. The only question now is how long it will last in its current state of pedal adjustment. I will continue to report back (bad or good).
- Made 5 passes
- Made 5 passes
The ACT performed admirably tonight - it met every expectation I had when I bought it. The only question now is how long it will last in its current state of pedal adjustment. I will continue to report back (bad or good).
- Made 5 passes
You should list what you did, clutch adjust, SS clutch line, etc
good job, was worried there for a while that u wernt going to be able to hit those 11's. glad to hear that u got ur clutch sorted out so that u can hit ur goal. so i guess u still have the option to be 2nd at 11's in a registered MR i guess, right?
The clutch will last. I have over 10K miles on my ACT and I have not had one problem with it. The clutch adjustment is the key along with regular fluid changes. My clutch rod is adjusted to within a few threads of the end also. This will give the clutch plenty enough room to fully disengage and prevent it from dragging the flywheel.
By the way excellent times!!
so basically it is a good clutch for the price. and the whole bad act story that was on the boards consistantly for last couple of weeks while u trashed talked the unit is because it was not adjusted right. before you go calling a part a piece of junk make sure its installed right. I know you discouraged certain people not to buy it based on your last thread. I was thinking twice. but on the upnote I'm glad it was just mis adjusted and it is a good unit. Good job on your 60ft.
