My newest ACT story (good)
The ACT performed admirably tonight - it met every expectation I had when I bought it. The only change since my disastrous trip to the track a few weeks ago is that I adjusted the pedal from 4 threads to 2 threads remaining on the rod. The only question now is how long it will last in its current state of pedal adjustment. I will continue to report back (bad or good).
thanks
Actually, yes, I just had to re-adjust the clutch again last week. I now have 1.5 threads left on my clutch rod, but it's shifting smoothly again. I don't know how long I will get away with doing this or what is causing me to need to do it.
I replaced the original flywheel with another stock flywheel. I may go with a lightweight one next time, but I'm not sure at this point.
so Warrtalon how long did the clutch last you & did you ever have the lockout issue again?
