AMS 2.3 stroker & 35R kit vs RNR 2.4 block & 35R kit: 91 Octane
Old Oct 2, 2005 | 09:13 AM
Smogrunner's Avatar
I like both set ups. The red lines below are from a very nice car with a built 2.4 4g64 block and the RNR 35R turbo kit and AEM ems.
The black lines are my car with the AMS 2.3 stroker kit with their 35R turbo kit with the Xede.
Both cars were on 91 octane with no h20 or other injection. My boost was 19psi until 7000rpms. At that rpm, boost creeped up to 20psi. I'm not sure what boost the other car was running but from the looks of things, it was probably very similar or maybe a touch higher.
Old Oct 2, 2005 | 09:16 AM
SMrider102's Avatar
i like the ams setup personally, but nice comparison
Old Oct 2, 2005 | 09:18 AM
IDRINKV8's Avatar
those are pretty low numbers for a stroker 35r is that the highest boost you can run with that kit on 91?
Old Oct 2, 2005 | 10:06 AM
954DRGSR's Avatar
Thanks for posting up this comparo Smoggie. Very interesting.
Do you know what cams the RNR guy was running?
Old Oct 2, 2005 | 10:11 AM
jj_008's Avatar
Interesting comparision. I bet the RnR car is using a larger A/R hotside then yours. Which is probably causing the later spool. Both should spool up around the same time regardless of EMS. That is amazing power on 91oct at 19-20psi.
Smogrunner's Avatar
Good comment. I'm not sure. I have straight hks 272s with my cam gears set at 0. I can find out later today.
Old Oct 2, 2005 | 10:16 AM
20valves20lbs's Avatar
Yes you are correect....the turbo wont boost any higher than this.
Old Oct 2, 2005 | 10:37 AM
LuxuryBroker's Avatar
Alfred, what do you think are the pros and cons of each set up?
Old Oct 2, 2005 | 10:45 AM
One of the major differences between these cars is that the RNR car is on a standalone ems. I tuned that car on pump..for some reason i couldnt find some of its dyno files. On 22psi it ended up making different numbers than the ones listed.....Let me have a little more time before I fully respond to this so I can actually give a fair comparison. I need a little more street seat time with smoggys ride.
Old Oct 2, 2005 | 11:44 AM
Smogrunner's Avatar
I could run another 2 or 3 psi and make a bunch more power, but I don't see the logic in running a "***** to the walls" 91 octane tune when I already have incredible power that is totally safe. When Tuning Technologies does their 91 octane shootout, we'll touch up the tune and run it another psi or two higher. That should be good for around 425whp and 380 torque.
Old Oct 2, 2005 | 12:34 PM
Yaroslav's Avatar
2.4 makes much more TQ....
Old Oct 2, 2005 | 02:35 PM
Fourdoor's Avatar
I'm pretty sure a GT35R will make 38 or more PSI.... care to eleborate on how the turbo will not boost any higher than this?
Keith
Old Oct 2, 2005 | 03:08 PM
KILTERMAN's Avatar
Keith
91 oct. and no inj. (alky)
Old Oct 2, 2005 | 03:15 PM
edwin's Avatar
thats quick!
Old Oct 2, 2005 | 04:54 PM
Wave's Avatar
Peak torque yeah, but check out about 1000 rpms earlier. The 2.3 is making a LOT more for a wider RPM band.
