just installed intake
Old Oct 3, 2005 | 09:22 PM
RaNGVR-4's Avatar
some cars (even the same model car) react differently to mods and venting to the atmosphere. some like it, most hate it if theyre MAF cars. either way its throwing your tune out the window durring shifts.
Old Oct 3, 2005 | 10:17 PM
electr0's Avatar
why is it throwing my tune out the window during shifts? ur saying a tuned car with vta bov is useless?
Old Oct 5, 2005 | 10:47 AM
inarut's Avatar
intake?
you need to have it tuned or go back to stock,you will run faster stock.
Old Oct 5, 2005 | 07:11 PM
RaNGVR-4's Avatar
a MAF carwill never run right, especially mitsu's and their Karmen style MAF when venting to the atmosphere. i know it sounds cool but it will never run right if you do it...
Old Oct 5, 2005 | 07:14 PM
Spec'd's Avatar
( sigh )
Old Feb 20, 2006 | 03:52 AM
Silvercar's Avatar
Originally Posted by dafarmer69
god dammit no it doesnt... just cause you think there isnt a prob there is... if you are not recicring you are causing the maf to get incorrect readings, causing it to send the wrong readings to the ecu. and so on.. will you people stop giving the wrong damn information... there is no damn diff either with 03-05 with the maf.. stop this wrong info giving people... unless you know what really happens when you do things halfassed keep your stupid comments to yourself... taenaive you know nothing.. like your name says, naive..
Well really the 05 MAF is designed slightly differnet very little change but is differnet. But still yes you need a tune if you get a intake.
Old Feb 21, 2006 | 03:20 PM
Swift_OwL's Avatar
When you say tune, do you mean a mail in flash or a dyno tune, to get the intake to work.
Old Feb 21, 2006 | 03:25 PM
nutrulz's Avatar
Just pour some water in to your intake to clean it out. Everything will be fine then.
Old Feb 21, 2006 | 04:24 PM
Warrtalon's Avatar
Ugh, by tune he means any tune. A mail-in flash is one type of tune. A dyno tune is nothing more than getting tuned on a dyno by any tuning device. It's not some magical thing a dyno does for you. A tune is a tune is a tune - without one, don't get an intake.
Old Feb 28, 2006 | 06:27 PM
Lgkaos's Avatar
Veteran: Air Force
I've tried searching...but just coming back with thousands of "which is best", "is this right", and the classic flame-retaliations. I'll just piggy back w/quick question.
I'm reserved to get tuned in 2 weeks down in Tucson (Im in Phoenix) (1.5 hr away drive). I'm interested and plannin on getting the Injen intake (already have lower turbo-side IC pipe installed). I KNOW that once the intake is on it requires a tune/reflash/_____.
Some people might just have the shop they're getting tuned at install the intake and tune it right away. Others like me, would rather save that $____/hr and do it themselves. My question is: Is it safe/do-able to install the intake myself, and then the next day or so (once proper installation verified)drive down to Tucson to get the tune that'll compensate for the new intake (plus other mods)?
No sense in getting the intake done locally, reflashed immediately for it, then driving down to Tucson to get a custom tune. Thanks for the help!
Old Feb 28, 2006 | 06:49 PM
fsugatorbait's Avatar
I did the same thing and was fine. I didnt notice any differences in the driving characteristics from stock box to Helix intake pre-tune.
Old Feb 28, 2006 | 07:03 PM
jfLip's Avatar
This is probably a dumb question, but is there any way to tell if my car is tuned? My Evo was bought used and it already had an AEM intake in it.
Old Feb 28, 2006 | 07:11 PM
vwjeff's Avatar
YES I couldn't agree more
Old Feb 28, 2006 | 07:18 PM
trinydex's Avatar
i don't get it... why does my intake work fine? no idle problems... nothing... i even have a biggie intercooler no tune... works fine... why???
i seriously believe that most of the poor idling etc threads from intakes is from dumb asses plugging the wrong **** into the wrong nipples and then coming here and whining. don't expect to get power from an intake. i did my intake for different reasons. but seriously... i'm one year wtih no toon... and **** works fine...
Old Feb 28, 2006 | 07:52 PM
sirploppy's Avatar
I have an 03 with just a Buschur intake without MAF pipe, and my car runs perfectly fine. This is with stock exhaust. IIRC on a previous intake thread it was mentioned replacing the MAF pipe changes the airflow enough to effect it more than just putting on a cone filter to the existing pipe, requiring a tune.
I do have one question though for proponents of the stock airbox. Why when Buschur tested an 03 and changed only the stock airbox did he gain 7ft/lbs of torque with no tune?
https://www.evolutionm.net/forums/sh...7&postcount=23
If someone can convince me this was an anomoly, I will forever convert back to the stock airbox side...
