Alky Question
Old Oct 2, 2005 | 10:50 PM
dsevo's Avatar
Alky Question
I couldn't find a straight answer. I am installing intake, tbe, head studs, walbro fuel pump, and alcohol. Do I need injectors if this is all I'm planning on doing for a while? I read that stock injectors will only support 23psi, but I also read that they are good for 400 hp which I won't make, so what should I do. Thanks
Old Oct 3, 2005 | 12:04 AM
dsevo's Avatar
Nevermind, I found that alky actually reduces necessary injector output by 10-15% because it acts as a fuel and requires less gasoline. I hope these alky kits are as good as their reputation. I'm hoping to make between 325 and 350 whp, but we'll see. I am gonig to have Tuning Technologies tune it.
Old Oct 3, 2005 | 05:17 AM
Ted B's Avatar
At 350whp on straight gasoline, you wouldn't need an injector upgrade anyway.
Old Oct 3, 2005 | 08:59 AM
dsevo's Avatar
I didn't know if injector sizing was related to boost, or hp because with alcohol I will be boosting 26psi even though it's only going to be around 350 hp.
