2005 Evo transmission issues....
Old Oct 11, 2005 | 08:23 PM
Nood1es's Avatar
05 with 5k miles, i get locked out from nething to 2nd. when it does go in it feels soo notchy havent tried changing ne tranny fluid. Would tranny fluid or changing the lines help?
Old Oct 11, 2005 | 08:33 PM
giumela's Avatar
I had a similar "problem" with my 03. You got to take it easy with the 1-2 shifts otherwise you're gonna F*#&# up your tranny and probably the syncros. I put a short throw shifter in mine and solved my problem. Hope this helps.
Old Oct 11, 2005 | 08:57 PM
Nood1es's Avatar
It just simple shifts from 1-2 at 3k, or downshifts from 4 to 2 as a light turns green. but if i downshift from 4-3-2 it goes in smooth.
Old Oct 11, 2005 | 09:06 PM
giumela's Avatar
do you rev match at all? if you rev match I don't see you having any shifting problems. I rev match all the time now and it makes a load of difference.
Old Oct 11, 2005 | 09:13 PM
Nood1es's Avatar
yeah i rev match every time. I dunno i mite just try taking it to dealer see if they can find the problem.
Old Oct 11, 2005 | 09:15 PM
giumela's Avatar
yeah do that....make sure you don't have any aftermarket stickers on it or they'll void your warranty
Old Oct 11, 2005 | 09:23 PM
Nood1es's Avatar
yeah stickers are a big nono.
thx for responses neway.
Old Oct 12, 2005 | 05:23 AM
vtecwrecker's Avatar
Originally Posted by deffro
How hard was the restrictor mod?
gravy man.. just follow this diy.
http://www.evomoto.com/tech_info.php...=3_4&tech_id=4
ignore the clutch line install if you arent installing one obviously.
Old Oct 12, 2005 | 09:37 AM
GTKage's Avatar
almost 15000 miles on my 05 and no problem what so ever, been to the track many times runs like a champ, low 13's all night long, stock clutch and tranny have no sign of problem ,lock out of 2nd gear couple of times, but i found out that my hand was faster than my clutch foot ( so that problem is driver related).
Old Oct 12, 2005 | 11:42 AM
oak2207's Avatar
Wow stock clutch? How many launches on it so far?
Old Oct 12, 2005 | 12:21 PM
GTKage's Avatar
i d say well over 20 now
Old Oct 12, 2005 | 12:24 PM
oak2207's Avatar
That's impressive... any particular technique? I think most on here will say you're approaching the limit.
Old Oct 12, 2005 | 01:18 PM
MaxR's Avatar
My evo shifts a little notchy like you guys describe, but its new, its supposed to be like that. Don't expect butter smooth shifts like a Toyota with 100,000 miles on the clock.
Old Oct 12, 2005 | 01:42 PM
USAF_STi's Avatar
I was at the track with jamie from WORKS, and he has over 100 launches with 30k on the clock and his stocker is still holding enough to give him consistent 1.8 60's.
Old Oct 12, 2005 | 08:39 PM
GTKage's Avatar
well just slip it slightly at around 4000-4500, if u smell your clutch it s means u slip too much, i dont get the best 60' (1.9-1.8) but at least i am saving my clutch and still run decent times.
