ACD bleeding for 05 evos..
hey
doing a clutch on an o5 evo..ive heard that the ACD needs to be bleed..yes or no..?
and what kind of proccess or tools would i need..? thanks for the help..
I am very curious about this ...and everything I have read says you need a 5 billion dollar computer thingy to connect to the acd ecu. You pretty much have to do your clutch ....then go to the shop to have your system bled.
It is just a pump ...so I dont see why we cant just hotwire power straight to the pump to bleed the lines?? It cant be that hard to come up with a hillbilly DSM style way to do this.
Ok guys, here is the deal, coming from the first car that came with it, Evo7, the thing is, most of the time that all 3 lights comes on, the system needs to be bleed properly, only thing is that the only proper way to do it is by going to the dealer and use the MUTII to be able to raise the correct pressure through the system and properly bleed it. Do not even bother to do it with the engine running, the system will never raise enough pressure.
Use the Mitsubishi Mutt 2 diagnostic tool, set to option #02 which runs the ACD motor, set ignition to on and bleed.
The problem is that the tool is proprietary to dealers and not for sale. We have solved this problem.
-Alex
www.dentsport.com
-Alex
www.dentsport.com
Any one else have more information on this? I'll see if I can find something. It would suck for those of us who actually do the work on our own cars. Bump for a very important THREAD!
-Alex
www.dentsport.com
-Alex
www.dentsport.com
