what spark plugs are you running?
Old Nov 15, 2005 | 10:16 AM
dbdude's Avatar
What gap should NGK BPR7ES be gapped at? When i bought them and checked the gap, they already came gapped at 0.28. So i just installed them in my car and it runs good. But now i wonder if the gap should have been bigger.
Old Nov 15, 2005 | 10:23 AM
rjdEVO's Avatar
autozone put evo in there comp and they didn't havre the ngk 7 iridiums,,,so the next best one they had was a bosch platinum 4,,,misfire bigtime,,,they are not the right size,,,don't work,,,got the 7 iridiums and no problems
Old Nov 15, 2005 | 10:28 AM
dbdude's Avatar
Nevermind. I just found the gap size at NGK's website. Its suppost to be 0.32. I probably lost power for undergapping. My plugs are probably 1 month old. Do you guys think i can pull them out and regap them and put them back in?
Old Nov 15, 2005 | 10:45 AM
05SilverEvoVIII's Avatar
still using the stock ones.
Old Nov 15, 2005 | 10:56 AM
fsugatorbait's Avatar
BR8ES here gapped at .028.
Old Nov 15, 2005 | 11:00 AM
boostfed's Avatar
Ditto...
I went ahead and got like 4 sets of these. I'll be changing them ever other oil change.
-Chad-
Old Nov 15, 2005 | 11:11 AM
Soon2BEVO's Avatar
I finally swapped out my BPR7EIXs this weekend and got a pair of BPR8ES coppers. They were gapped at 26 out of the box so I left them. My BPR7EIXs came gapped at 29/30, which I thought was kind of high but I just left them!
Old Nov 15, 2005 | 11:21 AM
thatsMR2u's Avatar
i got BPR8EIX they came pre-gapped at 28 but i was gettng slight misfire, i have similiar mods to you, so i gapped them down to 25 (yes there iradium so u have to do this super carefully) and now my car runs great with no misfires
Old Nov 15, 2005 | 11:26 AM
Soon2BEVO's Avatar
Yeah I was getting misfires with my BPR7EIXs and sometimes I got the P0300 code while idling..
Old Nov 15, 2005 | 11:30 AM
I started to get the p0300 code a lot during idling with the stock plugs. I have yet to get one with the switch to the coppers.
Old Nov 15, 2005 | 11:33 AM
Warrtalon's Avatar
Whoa, no. NGK doesn't know the proper gap for the Evo. You have it opposite; they should be .24-.27 like the manual says. I put my BPR7ES at .24, because I run high boost when on race gas. On street boost, this works as well...
Old Nov 15, 2005 | 11:38 AM
taenaive's Avatar
dang, this thread makes me experiment with spark plugs. I am using 91 gas which is very prone to the detonation even at 19 psi. Do you guys think that colder spark plugs will help?
Old Nov 15, 2005 | 01:52 PM
berkel's Avatar
Hey guys,
I'm running NGK bpr7es here, gap tightened slightly to ~.026 or so. I went through several months of dealing with a misfire near torque peak (4500 rpm) last winter, which ended up being caused by too much gap and Magnecor plug wires. Tightening the gap with copper plugs and going back to stock plug wires helped me love my car again.
I think that in general, tightening the gap will help if you are experiencing misfire. Too tight may be more prone to detonation or preignition. If you have detonation or preignition, it may help to switch to a colder plug. A colder plug can help keep cylinder temps down, but may be more prone to fouling. Lots of trade-offs, heh.
Iridium plugs are difficult to gap without damaging them. I broke a few when installing my wife's WRX. Copper is a good conductor, just need to change them more frequently. I've heard to stay away from Platinum for turbo cars, but I'm not sure why, lol. I've always used coppers and iridiums on my Audi A4, WRX, and Evo...
Generally, turbo and other FI cars need a tighter gap because of the high cylinder pressures. If you're ignition is good, running a little more gap may create a better/more efficient burn, but that probably wouldn't apply for us, since it would just misfire or the gain would be insignificant...
Good luck,
FB
Old Nov 15, 2005 | 01:57 PM
sleet's Avatar
I would suggest staying in the same heat range (7) with those mods. Go get some Copper NGK BPR7ES or Iridium NGK BPR7EIX. If you were running alky and 23-24psi daily, then I'd suggest you get some 8s (BPR8ES/BPR8EIX), but I don't think you need those right now and will run better on the 7s.
+1 I'm on the BRP7ES aswell, works perfect.
Old Nov 15, 2005 | 02:15 PM
Corey's Avatar
BPR7ES here and gapped to .26....
