550whp
Old Oct 9, 2005 | 04:43 AM
EVO-6.5 (KSA)'s Avatar
550whp
Hi to you the EVO masters outther i am on quist for 550whp and low 11 to hi 10
will this setup plus what i have on my car ( my sig )get me there
1-AMS short block with 2.3L stroker kit with Ross Racing Pistons (ceramic coated) and Crower conecting rods Rods .
3-ARP Head/Main Studs
4AMS EVO 8 Fuel Rail in (RED)
5-HKS Twin Power DLI II
7-HKS Head gasket Evo VII/VIII 1.2mm
8-Full 4G63 Engine Gasket Set
10-Tomei Oil Thermostat Killer
11-Magnecor wires
12-Power Enterprise Serpentine Belt Evo VII/VIII
13-1MM valves over size valves (ceramic coated) + Suptertech dual valvespring set, including titanium retainers and spring seats
14-(4G64) valve lifters
15-AMS GT35 with MAF
17-Defi D Series Boost Gauge (Black face)
18-Defi D Series Fuel Pressure Gauge (Black face)
19-PLX M300 Wideband 02 Meter
21-Helix Universal Catch can (Z1 to substitute Cusco catch can)
22-GReddy Reinforced Timing/Balance Shaft Belt ( if retaind by the stroker)
23-Magnecor wires
thanks and best regards
Old Oct 9, 2005 | 09:17 AM
VTEC Killer's Avatar
I noticed there was no mention of an engine management system in your mod list. I would recommend some sort of standalone to make all the parts happily work together. You do not need the 1mm oversized valves or the double valve springs. You can just get stainless stock sized valves and upgraded single valve springs and you will be OK for use of any of the HKS cams, if you use a high lift cam like Tomei or Piper then you want double springs. Also your mistaken about 4G64 lifters, they are not like even lifters in any way, they wont even fit in the same place as EVO lifters. Just get a new set of stock lifters. Any lifter for a 4G63T motor will work, make sure you get the ones with the 3mm oil hole. YOu can find them on ebay for about $125 for a full set. With all those mods and a good tuner you can make 550whp pretty easily. There are people who make over 500whp on stock engines with just cams, GT35R turbo kit, standalone, bigger injectors and upgraded fuel pump and a nice exhaust.
Old Oct 9, 2005 | 12:30 PM
alright by me's Avatar
i don't mean to hijack the tread but i am also looking to make 550whp reliably on pump gas as an everyday driver but was thinking along the lines of a jun 2.2 and a gt35. Any input is greatly appreciated. The price of parts doesn't matter as long as its reliable
Old Oct 9, 2005 | 04:14 PM
Bimmubishi's Avatar
Looks good man. For a street car I'd keep the oil thermostat though.
Old Oct 9, 2005 | 04:17 PM
evo_il8's Avatar
ur not going to make 550whp on pump, unless you use alky
Old Oct 10, 2005 | 04:34 AM
o i forgot to mintion the car Apexi power FC for the ingine mnagmint
what do you think
Old Oct 11, 2005 | 01:57 PM
so what do u think is it dowabol
Old Oct 11, 2005 | 02:25 PM
RyanM's Avatar
I like the list, but there are some questionable items.
#1. The dual valve springs. I would not go with this configuration. I know alot of people swear by it so I'm not trying to start a flame war. Its harder to get these spring rates to match perfectly and stay matched over time. I have crower springs and they work great. Make sure to consider piper cams, not many people are running them in the US but they kick a$$.
http://www.pipercams.co.uk/NewPiperW...CamFrames.html
#2. Crower rods are good, I always tend to lean towards Crower. There are many good choices. Also check out Manley
http://www.manleyperformance.com/newproducts.html
http://www.crower.com/cat/import/mitsu/rods.shtml (does not show up on their site, but they exist)
#3. Rather than go with a taller head gasket, why not go with the cometic at the stock thickness and run a range colder plug? Cometic makes a hell of a product...
#4. I don't know about adding the fuel rail with that FPR--I'd go with what AMS recommends here but I would not just add that fuel rail without a long conversation with them. Also, I don't know if the 720cc injectors are going to be enough for what your looking to accomplish.
#5. Magnecor are good wires, I think it helped smooth my car out a little bit--and I'm only running the 8mm and not the 8.5
#6 Rather than going with that upgraded balance belt, go with a balance shaft eliminator and get your crank balanced/knife edged.
#7. I'd add Ralliart motor mounts and a torque damper. (both available from Gruppe-S)
http://www.gruppe-s.com/Evo/evoeng.htm
Just my 2cp
Old Oct 12, 2005 | 03:51 AM
thanks for the reply
