Clutch died...again...
So, I weasled CarMax into replacing the clutch last time (19k miles) now @ 43k miles it is slipping a little again.
CarMax replaced the stock flywheel also at 19k miles.
SO... now Im going to get an aftermarket clutch since I have to pay for it...and wondering do I have to get a flywheel too? Is the stock flywheel good?
Suggestions, comments, flames, etc.
CarMax replaced the stock flywheel also at 19k miles.SO... now Im going to get an aftermarket clutch since I have to pay for it...and wondering do I have to get a flywheel too? Is the stock flywheel good?
From: Where Ever the Smoke and Rubber takes me.......
You may want to try a Fidanza FLywheel and an ACT. It's a good combo and your car will love the less weight on the wheel. Plus all you have to do when you replace the clutch again is to replace the heat sheild on it.
you guys with the ACT/fidanza combo, how much did you guys pay? How's the engagement? Is it heavy? Does the ACT clutch cause problems? I've heard some bad stories about them. Does the flywheel rattle on idle?
I am hearing some TOB noises, some said its normal and some said it is indicating possible dying clutch so i am looking at some options.
Thanks guys
Thanks guys
Originally Posted by JoeWalker4G63
^^Did you get the ceramic disc?
Well to answer the question, yes your better off replacing it. My question is how light of a flywheel are you guys using? I have the WORKS 10# and im sure on a road coarse or auto-x it would be great but IMO it makes launching a PITA. I like the feel of it, teh car revs up pretty quick, but makes launching a bit trickier.
I used to run the Fidanza aluminum flywheel but went to a lightened stock unit due to the higher friction coefficient of the Clutch Masters kevlar disc. The alloy used in the stock flywheel handles heat quite well actually, I have heard it is similar to what is used in some of the M3's of fame back in the day. The lightened stock flywheel I am currently running comes in at exactly one pound over my old Fidanza, 10.5 lbs. Believe it or not that one pound made modulation of rpms much easier than that of the Fidanza both during launching and daily driving. Not downing Fidanza's product, just had to come up with another solution for my particular application.
Get the Exedy Twin Metallic ... regular if you like a light pedal feel, HD (heavy duty) if you don't mind a slightly heavier clutch pedal feel. I'm pretty happy with mine so far (4 days and 1100 miles, fwiw)
l8r)
l8r)
