need help evo not runin HELP ME PLEASE!
Old Oct 9, 2005 | 12:34 PM
sleeperevo8's Avatar
Unhappy need help evo not runin HELP ME PLEASE!
i'm having a little problem with my car or it could be a big one i hope not if you could help me out . i was drivin goin bout 20 and it just quit on me i checked everything its getting fuel timin isgood, fuses are good changed the plugs out. not sure whats goin on. i wasn't hard on it when it happen. left the house and five mins later it happened i was even goin downhill any thoughts on what it could be
Old Oct 9, 2005 | 12:38 PM
Ralliartist's Avatar
Sounds broken. Time for a new one.
Seriously, maybe check your electrical system is grounding correctly. I had a car once that the ground came loose and it would just die, and even the mechanic was dumbfounded by it. Eventually I detected the issue more or less by accident, and fixed it.
Old Oct 9, 2005 | 12:39 PM
ev-slo's Avatar
We need a little more info, If you go to start it what happens. Does it try to kick over? Do you hear your starter start? Try jumpin' it? Try disconteting your battery for about 10 min, connect it again, turn the key and let it sit then try and start it.
Old Oct 9, 2005 | 12:42 PM
turns over but doesn't start battery is good it has 2 optimia in it haven't tired disconect i'll try that now
Old Oct 9, 2005 | 12:45 PM
would buy a new one but it has to many upgrades can't afford a new one
Old Oct 9, 2005 | 01:22 PM
EvoVIII_MR2005's Avatar
Disconnect the battery, leave it for 10-15 minutes and then reconnect it. See if that works.
Old Oct 9, 2005 | 03:34 PM
Nad1370's Avatar
Quick check on your MAF connector. Could have fallen off.
Old Oct 9, 2005 | 03:41 PM
Steven's Avatar
What mods are on your car? How long have they been on? What's the last part that you installed? Does the car have spark? How do you know it's getting enough fuel? I need more info to help diagnose.
Old Oct 9, 2005 | 03:58 PM
turbo kit , afc, fuel pump, injector full exhuast, aem uego, and intercooler piping few other little things that wouldn't cause the problem i've had the mods for well over a month i disconected the battery over an hour still does same thing but i did find out that the car is not getting a spark i uplugged the plug wire and put in a plug with plug ground it had no spark while trying to start if
Old Oct 9, 2005 | 04:25 PM
last part installed was a new waste gate car was runing perfect when a left the house this happened within 5 mins bout car was started for 10 mins to warm up before i left this is my first time i've had any problems with my car besides puttin a new clutch in
Old Oct 9, 2005 | 04:39 PM
hotrod2448's Avatar
Did the Utec take a sh*t? Maybe fried coil packs? Try putting in the factory ECU and see if it gets spark if nothing else maybe it will give you some trouble codes to look up.
Old Oct 9, 2005 | 04:42 PM
avengerhed's Avatar
check the ECU fuse...sometimes the after-cat O2 sensor can short to the body of the car and blow the ECU fuse which would cause the symptoms you describe (engine turns over but no spark) if it is the ECU fuse, fix the wires on the O2 sensor
Old Oct 9, 2005 | 05:14 PM
i checked all fuses but i'll check again just to make sure the engine light does stay on now before it use to turn off when i jus click the motor over a little even if i start it for a second the turn it off without taking the key out of the on thanks for everyones help i really apperciate it i've been the only one to work on my car theres know one around that really knows anything bout evos round here so ussually if something goes wrong i know exactly what it is
Old Oct 9, 2005 | 05:43 PM
i still have the factory ecu in a don't have a utec just the acf 2 and it all checks out fine coil pack could be fried i'm gonna take it out and go try it on another car
Old Oct 9, 2005 | 05:56 PM
hotrod2448's Avatar
Sorry, I saw Uego and read Utec my bad. Why not find someone with a code reader and see what codes are logged then? You may be able to rent one at your local autoparts store.That will defiantely get you heading in the right direction. Remember OBD is your friend.
