clutch installed...cant get car into gear!
Old Oct 9, 2005 | 01:12 PM
Sap12687's Avatar
Everything is perfect after the install except the car will not go into gear. The shifter floats around and doesnt grab anything. I checked the cables and they're connected. The small one above the larger one, like its supposed to be.
I noticed there is a swinging joint where the small cable connects and theres a dowel for something but there isnt anything on there. What is the 3rd connection?
Old Oct 9, 2005 | 02:37 PM
Sap12687's Avatar
i just looked again and it looks like there is a piece im missing that attaches the large and small cables to the main output piece....not idea what it is called. It a square with a "u" carved in the middle.
Is mitsu. going to have this part in stock? Anyone know what its called or what the part number is?
Anyone know what the hell im talking about?
Old Oct 9, 2005 | 02:52 PM
fromWRXtoEVO's Avatar
A common issue is that people use to drive in with a gear engage. Once you remove the tranny the cables must be install accordingly.
Make sure you are in neutral, undo the shifting cables and makes sure you install/engage them back into place again while in neutral.
If you don't have the shifting cables install correctly the car wouldn't shift at all.
bustin
Mar 18, 2018 05:44 PM
Billy's MR
Feb 28, 2017 08:00 AM
Mcamacho
Lancer Troubleshooting
Apr 10, 2015 09:29 PM
From 3 to E
Nov 10, 2010 09:04 PM
MrHouse
Jul 14, 2010 01:13 AM
