Your thoughts.....
Your thoughts.....
Clutch
Good price?? Good clutch for daily driver, limited to no track use?? Stock clutch is slipping and its time to replace and i dont need some big badass super clutch!!
So our clutch is made by Exedy?? I thought it was just like a OEM Replacement, but made by a better company. Ok, so this Exedy HD Twin sounds like its way more expensive then what im looking to spend on a clutch. $475 shipped isnt bad, What series ACT is it? How is it daily driver wise? Keeping in mind, im not looking for something that will hold a billion HP at the track!! Does changing the clutch change the pressure needed to depress and release the clutch pedal? If so, I need something thats fairly easy or close to stock due to a bad knee that acts up sometimes.
Originally Posted by carbonevo8
no I was refering to the one on ebay as the oem clutch.
Originally Posted by Warrel-a-thon
Exedy makes the stock clutch.
To the thread poster: As long as you're opening up your car to replace the clutch, definitely take the opportunity to upgrade, or you'll probably just find yourself in the same postition in a short while...
Steve - What exact clutch is it?? What is included with it.
Sorry, I was playing with Warrtalon, didn't mean to throw you off. That particular clutch is NOT an upgrade. As they've said, the OEM is made by exedy, and that's exactly what that ebay one is.
Originally Posted by smokedmustang
did you guys say the exedy twin metallic is the same as a stock clutch?!
seriously though, exedy makes the oem clutches for like everything, As far as I know they own the patent on pull type clutches.
