tubular O2 housing question
I'm getting a Helix O2 housing this week and am wondering whether I would be asking for trouble to use it without putting a high temp coating on it. I assume that the stock lower heat shield won't fit with this O2 housing? I don't want to cook everything down there running an uncoated piece without a shield.
Are others running this piece without a shield or coating without problems over the long term (1 year+)?
Thanks.
Thanks.
Many of our customers have experienced cracks & failure with inexpensive tubular style 02 housings. Coating tubular housings will increase flow by a minimal amount but not close to the efficiency of a thick cast housing similar to the stock unit.
-The best long term solution is a cast piece that retains all factory heat shields.
Our new WORKS 02 housing is a one piece cast 02 housing with factory tabs included to maintain factory heat shields.
-It fits perfectly in the stock position w/o any modifications.
check out the link:http://www.worksevo.com/store/produc...roducts_id=189
Now that we have the self-promoting, completely unresponsive advertisement message from Works out of the way, could someone with one of those "inexpensive tubular style O2 housings" please give a helpful reply?
Thanks.
Thanks.
damn dude he's just trying to help.... besides the cheap e-bay style one do tend to crack aolong the welds.
Take it to a good fab shop to get a little more material added between the wels and they hold ok.
Many people use the manifolds without coatings.
I, personally, do not have one, but I know many people who do, and they have no issues with heat.
If you are worried about it cracking from heat-cycling, that is not why they crack. They only crack when used in conjunction with a tubular manifold as well which supports the entire weight of the turbo and exhaust and consequently cracks because the tubular O2 housings don't have the support bracket.
If you will still be using the stock manifold, you shouldn't worry about it cracking as the OEM manifold is plenty capable of supporting the weight.
I wouldn't worry about it too much if you're sticking with the stock manifold.
As far as the heat shields are concerned, they really don't do much. Consider that they are metal as well, and will conduct heat and still get hot. I have been driving my car without any heat shields since Feb. of this year with no issues and I know other people who have done the same.
I ran the Helix O2 Housing for a while without the lower heat shield or coating, then removed it and had it coated by Jet Hot. I didn't have any problems (that I noticed) with cracking or overheating either way. I've been meaning to put the lower heat shield back in since even though 3/4 bolts aren't used, you can still use the top bolt of the lower heat shield on the stock exhaust manifold. I've been told that it stays in place just fine with that one bolt. Oh yeah, make sure to use some cardboard on the backside of the radiator or just remove it completely for the install
Thanks.
Thanks.
Thanks.
Thanks.
Anyway I just purchased a Megan 3" o2 housing that I will be installing shortly. I plan on gasket matching it to the turbine housing and having both coated along with a spare mainfold (which i don't have yet). I'm going to do this over the winter and I'll make a post detailing the process. I have a MR 3" TBE and am very happy with their products... paying $400+ for an O2 housing is ridiclious.
I coated my 3 inch RNR because I removed the lower heatshield and to increase velocity. It still gets really hot even when coated with a 2000 F coat. Useless info: 2.75 for MR not 3 and 2.5 for the Helix.
I've been running the helix o2 housing with an aftermarket exhaust manifold, no heatshield, and a bigger radiator with no problems other than the o2 housing is a pain to install. Follow Syrihl's advice about the radiator and you should be ok.
Im sorry but whoever specked that piece out should be fired. If you have to price it that high to make your margin than your production is horribly inefficient. You can get a complete TBE for less than that shipped. For christ sakes you offer a complete bored TB for less than that with core.
i have the helix 02 housing, works great. give a little faster spool up. i don't think it's that much gain on the hp side. no crack at all, i drive my car like it's stolen all time. i have good amount of power mods too. 345whp dyno at Tuning Technologies. The works o2 housing is a very well build piece, but for the price i would get something have more gain like 272/272 cams or something else.
