cams and gas mileage - share experiences
Hah... our mileage is about to drop for re-formulated winter gas crap is coming.
Expect a 2-3 mpg drop.
264 i/e. average 250 - 280 a tank. I think my stock injectors are keeping my mpg in check.
i get about 240-270 miles per tank, i dont drive in high boost that much though. The times when i do do alot of spirited driving i tend to see about 200 miles to the tank staying in boost alot. I have the 272's. my mileage increased slightly with the addition of cams and a flash together.
Originally Posted by Ted B
I'm using HKS 280s with an aggressive setting that enhances midrange torque, which increases efficiency in the rpm range where the engine hovers at 75-80mph.
My best experience so far has been 375miles on a tank, not hitting the reserve light until 335 miles.
Originally Posted by dan628
what do you mean winter gas?? I never heard of that or had any problems with lower gas mileage on my other cars in the winter. I don't plan on driving my EVO in the winter anyways, but I'd like to know a little more on what you mean.
http://www.zhome.com/ZCMnL/PICS/wint...winterGas.html
i get at least 275 every tank before the light comes on , i dont have cams though i do have a vta hks bov which will be recirculated soon, ill check to see if theres a difference.
Can't use the recirculation kit with HKS version 2... when the BOV is not in stock location the hose is going to be really long to recirculate it..
Originally Posted by Apex Buddy
ev08buoy, why don't you just buy the 20 dollar recirculation kit for the hks?
The only thing I can think of as far a "winter" gas is actually diesel fuel. There are various grades that have lower gel points. In the midwest we have to run "#1" from December through February--which is more expensive. There are also differences in application, anything running on the highway is federally mandated to use the 15ppm sulfur content fuel. Some farmers try to get away with running the 500ppm stuff that they run tractors on in their pickup trucks--but if they get caught the fines are amazingly high. Most of the modern turbo diesel trucks run like *** on the 500ppm stuff anyway so the offset in mileage doesn't balance out the savings
Here is a description:
http://p66conoco76.conocophillips.co.../3736/FAQ1.pdf
1. Grade No. 1-D S15, a special-purpose, light middle distillate fuel for use in diesel engine applications. Higher volatility than that provided by Grade No. 2-D S15 fuel. Maximum sulfur content 15 ppm.
2. Grade No. 1-D S500, a special-purpose, light middle distillate fuel for use in diesel engine applications. Higher volatility than that provided by Grade No. 2-D S15 fuel. Maximum sulfur content 500 ppm.
3. Grade No. 1-D S5000, a special-purpose, light middle distillate fuel for use in diesel engine applications. Higher volatility than that provided by Grade No. 2-D S15 fuel. Maximum sulfur content 5000 ppm.
4. Grade No. 2-D S15, a general-purpose, middle distillate fuel for use in diesel engines, especially in applications of varying speed and load. Maximum sulfur content 15 ppm.
5. Grade No. 2-D S500, a general-purpose, middle distillate fuel for use in diesel engines, especially in applications of varying speed and load. Maximum sulfur content 500 ppm.
6. Grade No. 2-D S5000, a general-purpose, middle distillate fuel for use in diesel engines, especially in applications of varying speed and load. Maximum sulfur content 5000 ppm.
7. Grade No. 4-D, a heavy distillate fuel, or a blend of distillate and residual oil, for low- and medium-speed diesel engines in applications involving predominantly constant speed and load.
Also, if they are changing the chemical content of the fuels for different times of year, they would have to make different MSDS labels--which after searching, I have not been able to find
Here is the p66/76/conoco MSDS site
http://w3.conocophillips.com/NetMSDS/
If you do a search with a blank field, you will get 654 results. Notice that the third choice is for Conoco Unleaded Gasoline--that MSDS is from 2003 and it is their current MSDS
Originally Posted by RyanM
Also, if they are changing the chemical content of the fuels for different times of year, they would have to make different MSDS labels--which after searching I have not been able to find.
Higher vapor pressure usually implies lower density which does tend to decrease mileage. The biggest hit in winter though is the longer time your car spends in cold enrichment mode.
Dave
