Forced Performance Camshafts
Old Oct 13, 2005 | 09:38 AM
electricevo's Avatar
I was wondering if anyone has had any experience with any of the three grinds forced performance is offering. Because they show actual durations and lifts (not advertised like HKS and Revolver), is there a formula that can be used to plug in the numbers other companies show to come up with an actual durations? These cams are only 219 a piece for intake and exhaust, which seems to be a really good price from a reputable company, but i am looking for personal experience/knowledge on them. Heres the link: http://linux.forcedperformance.net/m...ode=Lancer_EVO
Thanks in advance.
Josh
Old Oct 13, 2005 | 09:42 AM
RyanM's Avatar
Piper also advertises the actual durations...
http://www.pipercams.co.uk/NewPiperW...CamFrames.html
These are interesting, I'm not sure what the logic is though
GROUP A
217 deg 212 deg
265 deg 267 deg
.453"
11.50mm
.378"
9.60mm
106 deg 108 deg N/A N/A HYDRAULIC £529 Blank
Less lift and longer duration on the exhaust side... That's even less lift than stock. I'm wondering what the reasoning was there.
RACE
224 deg 224 deg
272 deg 272 deg
.472"
12.00mm
.472"
12.00mm
108 deg 107 deg N/A N/A HYDRAULIC £529 Blank
Old Oct 13, 2005 | 10:55 AM
CFaber's Avatar
lots of talk of these on the "DSM" boards, but I haven't seen much here myself.
Old Oct 13, 2005 | 03:46 PM
sayanara's Avatar
pipers are good cams with alot of lift.
Old Oct 13, 2005 | 08:18 PM
RSGuy's Avatar
A friend of mine recently installed the FP 272 cams in his GSX and he loves them. I think they're worth a shot.
~fred
Old Oct 13, 2005 | 08:21 PM
2ggst's Avatar
i think this is the first thread i've seen these cams for the evo. as some of you guys have stated, a lot of dsm guys are using the fp cams now. i haven' t heard of any problems at all. now who's gonna be the first to try these?
Old Oct 13, 2005 | 10:31 PM
Z1 Performance's Avatar
billets or regrinds?
Old Oct 13, 2005 | 10:45 PM
NDgsx's Avatar
New billets. On DSMs the 2s have made more power than the 272s with a much nicer idle.
I ran the 3s on my 2.4 and picked up 3mph off of my 272s.
Old Oct 14, 2005 | 01:35 AM
inco9nito99's Avatar
I have FP2's on my Eclipse..amazing product. Nearly stock idle, and makes the same if not more power than the HKS272's up top. FYI they're made by Comp Cams, but COMP 0100's and 0200's are NOT the same as FP1/FP2. FP designed, Comp made for sale by FP. HTH.
Old Oct 14, 2005 | 05:59 AM
MisterMR's Avatar
Question
So what combo of these would be the same or similar to HKS 264/272??
Old Oct 14, 2005 | 01:29 PM
Hks 264= Fp1
Hks 272= Fp2
Hks 280= Fp3
Old Oct 14, 2005 | 10:25 PM
NDgsx's Avatar
Originally Posted by inco9nito99
Hks 264= Fp1
Hks 272= Fp2
Hks 280= Fp3
The FP3 is not at all like the HKS 280. It was designed specifically for the 100mm stroke engines and their higher piston velocity. It has very aggressive ramp profiles and holds the valves near full lift MUCH longer than any other cam on the market. Compared to a HKS cam the lobe looks downright square.
The only downside is they require strong dual springs, I ran supertech duals on my car which are 250lbs at full valve lift and around 96lbs seat pressure.
Old Oct 15, 2005 | 10:16 AM
mttam510's Avatar
Thanks in advance.
Josh
Our intake cam @ 1mm or .040": 222 deg., @ 1.27mm or .050" : 218 deg., @ 2.54mm or .100" : 192 deg. Exhaust cam: @ 1mm or .040" : 223 deg., @ 1.27mm or .050" : 219 deg., @ 2.54mm or .100" @ 194 deg.
Old Oct 15, 2005 | 06:28 PM
Awewome! thanks for all the input on these guys, i really appreciate it. I get a sense that these are well worth the money. Ill update with review on the fp2's if i go this route as i am still doing some research on these.
Aniel
Feb 5, 2016 07:08 AM
evoIXcencal83
84
Aug 28, 2013 09:04 PM
JScocchio
May 30, 2011 03:29 AM
evotris
26
Aug 24, 2008 09:29 PM
EVOla_VIRUS
Jun 13, 2006 05:51 PM
