FP Evo Flow Advancement Port Cover
Old Feb 25, 2011 | 07:37 PM
evoIXcencal83's Avatar
I recently purchased a very low mileage old style FP green to use on my 8. I was wondering what would be the benefits, if any of upgrading the compressor cover to one of these offered by FP...
http://store.forcedperformance.net/m...e=Lancer-Turbo
I was thinking that maybe performance would fall somewhere between a basic green and the HTA version. Any insight would be much appreciated.
Old Feb 25, 2011 | 07:42 PM
EVO8LTW's Avatar
Do they sell one for the old green?
Old Feb 25, 2011 | 07:46 PM
goodhart's Avatar
I don't think you will see any gain due to the fact that it the HTA uses a different compressor wheel. An anti-surge housing is typically a small hit to power as well. Someone correct me if I am wrong.
Old Feb 25, 2011 | 07:50 PM
Im not sure, but if there were any substantial gain to be had, Id def be interested for only $200.
Old Feb 25, 2011 | 08:11 PM
okevolutionVIII's Avatar
There's threads on this already and the gains are worth the money IMO. I plan on using one when I install my old Green. Just do a search and read all about it
Old Feb 25, 2011 | 08:18 PM
still*boostn's Avatar
yeah but will it just be able to be slapped right on or will a "custom" one be made?
Old Feb 25, 2011 | 09:04 PM
I searched and couldnt find anything, a link would be great!
Old Feb 25, 2011 | 09:19 PM
Search the exact name of your thread on Google.
Old Feb 25, 2011 | 09:22 PM
Evoleader88's Avatar
hey guys... i had an old skool green b4 and thought of doing the same thing... but this is what Fp told me: if u have an old skool green (which is 5 blade wheel) u cant use this cover (84mm), u can upgrade only if ur green is 64mm HTA (which is 7 blade i think)
Old Feb 26, 2011 | 05:27 AM
Which one would fit an old FP green?
Old Feb 26, 2011 | 10:01 AM
the 84mm cover wont fit the old skool green... it only fit the HTA green
Old Feb 26, 2011 | 06:26 PM
Boost Demon's Avatar
Veteran: Air Force
$200 would be better spent elsewhere IMO, but FP would be able to tell you best.
Old Feb 26, 2011 | 07:07 PM
sparky's Avatar
I am not so sure that this statement is correct. I know for a fact that there is someone on these boards running the 84mm cover on a stock IX turbo. So, there should be an FP anti-surge cover for the O.S. Green. But maybe I have had a few brews too many.
This might possibly be advantageous on an O.S. Green if the person were to go to a speed density setup and run a straight through 4" intake from the air filter exit up to a reducer right before the compressor inlet.
Old Feb 26, 2011 | 08:04 PM
Erik@MIL.SPEC's Avatar
FP actually sells a FAP for the stock Evo turbo.
Also, the OP could upgrade to the HTA 71 comp wheel which is what I will be doing eventually.
Old Feb 26, 2011 | 08:14 PM
Are you saying that the HTA71 wheel will bolt onto the OS Green without any modification or it's upgraded through FP?
