Exhaust leaks, Big deal or not??
I can feel a little air leaking before and after the cat when my car is at idle. Is this a big deal , am I losing power? I would think im not losing any cuz the air still comes out of the exhaust. I have a TBE by the way.
We put the metal gaskets and tightened as much as we could and there are leaks still. Do you think i can use some of that high temp gasket maker? I think that would seal it for sure.
It may and may not work. I have a leak between the DP and 02 housing. The gasket didn't work for me.
i have the same issue. small leak between my mid pipe and test pipe. i am running the mechanical O2 fix so no cell. i am going to fix it because of the sound, but not sure if i can take my sweet time or not (read: im lazy) will i screw anything up if i leave it be for a bit? how big of a power loss could it be?
Anyone know if I can get one of band clamp locally at pep boys, napa, or something. I have the BR TB and one of the clamp have loosen up to the point where it will not tighten up.
I don't think I can substitue it with the regular exhaust clamp.
