Exhaust leak
Old Oct 24, 2004 | 04:45 PM
WADADLIG_OZ's Avatar
Exhaust leak
Just wondering what kind of effect on performance having an exhaust leak between your downpipe and cat will show.
The gasket was bad and was leaking air big time.
WADAD
Old Oct 24, 2004 | 04:52 PM
pgmike's Avatar
at that point in the exhaust system, it shouldnt make too much of a diff, a little in the low end and it wouldnt hurt in the topend. how big was the gap?
Old Oct 24, 2004 | 05:34 PM
Not a big gap.
Just enough to let hot air out if you held your hand there. Made the car a little louder.
WADAD
Old Oct 24, 2004 | 05:38 PM
pgmike's Avatar
yeah it shouldnt make much of a difference then. you feel a differnce when driving?
Old Oct 24, 2004 | 05:40 PM
I'm not sure. I am trying to figure out if the exhaust leak helped on my top end performance. The 2.25 custom catback was supposed to improve things big time over stock piping but hasn't really happened.
WADAD
Old Oct 24, 2004 | 06:10 PM
ghostrider's Avatar
I would think it actually hurts the top end a good bit. Instead of the gasses traveling the full distance of the exhaust it terminates early and doesn't give the same amount of push.
Old Oct 25, 2004 | 05:34 AM
GreenPsycho's Avatar
we aren't talking about a rocket or jet here dude, the expulsion of gases don't effect the cars movement
Old Oct 25, 2004 | 03:20 PM
twardnw's Avatar
yeah, but a 4 cyl depends a fair amount on having backpressure
Old Oct 25, 2004 | 03:47 PM
Nm0ney34's Avatar
Id say it hurt him a bit. That whole backpressure crap
how did u find out? did u change it when u installed the catback?
Old Oct 25, 2004 | 05:47 PM
ghostrider's Avatar
So backpressure plays no role in power then?
In that case I don't know why companies spend r&d money on testing flow characteristics of manifolds and exhausts.
Old Oct 25, 2004 | 09:37 PM
i didn't say that, however, but if you'd like to take my words and twist them to fit your agenda go right ahead rocketboy
Old Oct 25, 2004 | 10:10 PM
Nm0ney34's Avatar
rocket man...
Old Oct 25, 2004 | 10:22 PM
pgmike's Avatar
dont insult or try and argue with a knowledgeable well-standing member, n00b
Old Oct 26, 2004 | 03:17 AM
ghostrider's Avatar
So just how much backpressure is needed to ensure good power then? Is it ok to chop the exhaust off at the end of the downpipe? Will that provide better gains than a full exhaust?
There's people that have done things like chop off exhausts from cars because they "heard" it would provide gains since it removes restriction. Companies have turned around and dyno charted this method and guess what? Doing that lost hp and tq all across the powerband instead of providing any gains.
So I'll ask again, how much do you know to validate your original statement?
Old Oct 26, 2004 | 04:13 AM
Yes I found out I had a leak when the catback was installed. I used to hear the car backfiring slightly but thought it was the header opening things up.
WADAD
