AMSoil MTL SAE 75w90 GL4 (Tranny)
Old Dec 28, 2005 | 08:06 PM
GTREVO's Avatar
I have tried Redline, Motul for my LSD equipped evo gearboxes but sadly the only one that will work perfectly is the Amsoil AGL Synthetic gear oil 80W-90. Works like a gem with solid smooth shifting at all weather even when auto crossing in extreme temperatures. In the morning its bit notchy but works perfectly after a short drive. The rest fails when the temperature goes up and have even contributing to high rpm grinding during shifts... if you ask me, Amsoil it is all the way...
Old Dec 28, 2005 | 08:30 PM
evolved4g63's Avatar
I think i remember about a year ago, a vendor was using this throughout the entire driveline. Tranny, tc, and rear diff. Was working great from what i remember. If it works in all the high revving 2 strokes and racing applications its gotta work for the evo 2. If only it was as easy to get as royal purple.
Old Jan 8, 2006 | 08:08 AM
Deepseadiver's Avatar
I changed my transmission fluid to AMSOIL and the car is shifting much better.
Old Jan 8, 2006 | 08:21 AM
Redcloud's Avatar
I don't use the tranny fluid but I do use the AMSoil engine oil 5w30. I changed from Mobil1 at 50K miles and I now have 109K miles with no issues. I'm currnetly putting down 340WHP. The AMSoil is an extened use oil so I change the oil every 7500 miles. The most oil I've had to add between changes was 1/4th of a quart. My gas mileage went up about 8% also.
Old Jan 11, 2006 | 01:31 PM
evo150's Avatar
Just changed my tranny fluid with the amsoil. i ordered it directly from them and with shipping total came to 30.73. so far i am very happy with it
Old Jun 11, 2006 | 01:35 PM
Bloomie's Avatar
AMSoil Gear Lube
I have used AMSoil 75W90 S2000 in the transmission of my 2003 Evo for the last 20K miles. It made the gearbox much smoother on the street.
There has been a lot of discussion in various threads about GL-4/GL-5. AMSoil rates this lube as GL-2 through GL-5.
But, after 15 minutes or so on the track, it becomes very easy to shift through the synchros on the 3-4 change. It takes a 2-3 second hesitation for them to do their job. No problem until the gear oil heats up. The same thing happens after 3 hours or so on the road.
Obviously, as it heats up, the friction characteristics of the lube change. Of course, I could never get the local Mitsubishi dealer to address the problem, because there is no place near the dealership that I could do a 3-4 shift at high rpm because of the speed. It shifts just fine at lower rpm.
My AMSoil rep replaced the fluid for me, but it didn't help. At least I know that the problem is not caused by breakdown.
I'm changing to some combination of Pennzoil Synchro/GM Synchro/Redline. Based on the threads on this topic, it appears that a Pennzoil/Redline blend might give me some improvement.
BeyondLimitsEvo
17
Jun 5, 2015 03:18 PM
Clipse3GT
15
Jun 19, 2012 06:54 AM
itsme4g63
34
Mar 3, 2008 02:57 PM
schred86
35
Nov 1, 2007 12:00 PM
thestaton
Jan 12, 2005 02:44 AM
