AMSoil MTL SAE 75w90 GL4 (Tranny)
Subscribe
Oct 16, 2005 | 11:32 PM
I am a longtime BG user from my previous 2003 Evo, but decided to try AMSoil new GL-4 manual transmission lube after I finally got my Karboy shortshifter and bushings installed. Car has 1500 miles, with the normal OEM notchy shifting B.S. from the factory. Dumped the old fluid out (which still looked new btw), and put 2.9 qts of AMSoil in.
Performs just like BG Syncroshift or even better. Notchyness is totally gone (except for slight 1st gear notch which is normal). Totally happy so far with this fluid, and I like that it is actually rated GL-4 and SAE compliant. I will give a longer term review once I put about 5000 miles on the car. Already did some hard shifting near redline, and with the full Kartboy setup (knob, shifter, both sets of bushings) its like a dream going through the gears. "Riflelock" comes to mind.
Anyhow...just wanted to give a mini-review for those still looking for magic snake MTL oil
https://www.amsoil.com/storefront/mtg.aspx
Happy shifting.
Reply 0
Oct 17, 2005 | 12:16 AM
how many miles do you have right now?
Reply 0
Oct 17, 2005 | 07:30 AM
Mitsuorder was having good results with it... I think he ordered me some, but I've not been around to try it out.
Reply 0
Oct 17, 2005 | 07:53 AM
Can this be bought at local stores? I want to give it a try
Reply 0
Oct 17, 2005 | 10:10 AM
Dont know if it can be bought in local stores...I had to order mine from them directly. Only have about 100 miles on it, so not a comprehensive review yet
Reply 0
Dec 11, 2005 | 05:09 AM
Could this be used in our evo's without voiding our warrante unlike the synchromesh and synchroshift fluids.
Reply 0
Dec 11, 2005 | 05:24 AM
You said notchy shifting gone? how would you know whether or not its amsoil or kartboy
bushing cure it?
Reply 0
Dec 11, 2005 | 09:07 AM
Quote: You said notchy shifting gone? how would you know whether or not its amsoil or kartboy
bushing cure it?
I would think stiffer bushings would make the tranny seem even more notchy because there is more vibration through the lever, right?
Reply 0
Dec 11, 2005 | 09:09 AM
they stock this stuff down the street @ my local car quest its great stuff im using different grades of ams oil in everything in my evo and have been for the past 17k.....
Reply 0
Dec 11, 2005 | 11:06 AM
Yea try the motor oil too, its very good (10w30 turbo formula or even the 7500xl)
Reply 0
Dec 11, 2005 | 12:00 PM
could mitsu void my waranty for trying this stuff in the tranny? It does meet the "mitsu diaqueen OR 75w90 GL4 SAE" requirment. so it should be find under warranty correct?
Reply 0
Dec 11, 2005 | 12:12 PM
Mitsu has to cover under warrenty. It is rated 75w90 GL4.
After 2000 miles I can confidently say this is great gear oil. When the tranny is cold, its a bit notchy (have karboy full setup), but once warmed up, its a dream to shift. Feels like a bolt action rifle when I shift...which is what I wanted since my old 2003 Evo was set up this way
Reply 0
Dec 11, 2005 | 02:17 PM
I haven't really seen Amsoil products at any local stores, so you might need to order them from online stores.
Reply 0
Dec 11, 2005 | 04:57 PM
Since you're in AZ, check out Surge (on Rural and Gauadalupe). I don't think they have the GL4 Amsoil, but he's got a bunch of other Amsoil stuff and an account so he might be interested in carrying it.
Reply 0
Dec 28, 2005 | 10:52 AM
Good to know. How often are you changing the AMSoil GL4?
Reply 0
