Which BOV w/ Injen Intake System?
I am a newbie, and I have SEARCHED, but havnt found anything, I am about to order my intake and bov, Right now I am going HKS Race Suction Intake with HKS Ver. 2 SSQV BoV...But it is def. pricey...so I was thinking about going with the Injen Intake system, but IDK which BOV i should use with it?? Does anyone know? Anyone with that set up??
thanks in advance
Bobby
thanks in advance
Bobby
Hey well guys actually I have done some reearch on this intake system and i have heard nothing but bad things about the injen, everyone says stay with the stock air box...so let me ask this question...who has the stock intake with an aftermarket BoV? and what BoV are you running?? thanks
Ok, I've got the Injen setup and have tried a few BOV's. I started out with the stock one, it started leaking. I then went with the JDM MR BOV and it held great...until I went to the track and tried running 28psi, it started leaking. Now I'm on the Forge RS Recirculating valve. Easily holds as much boost as I tried putting to it (28psi last month). Only thing is...it's hard to get it to NOT flutter. If you don't mind sounding like a rattle snake every-so-often it's not a big deal. All 3 fit, I'm not sure how many other one fit on the Injen kit.
I had an APS BOV with the stock airbox and I recently upgraded to the Injen intake and used the APS BOV as well and I am very pleased.
This is a great intake system, very nice construction and install perfectly.
I am running straight 272's with this intake and no flash and I have NO idling or stalling issues.
Lesson at hand- people ***** too much.
jdm dv is our stock bov in metal. our plastic bov leaks often. not much extra noise if that is what you want. aps twin vent recircs and makes a little extra high chirped noise. not like a gunshot. jdm is cheaper and will hold boost just as well as an aps. all other bov are a waste unless you are running some extremely high boost constatntly, like 25 lbs. stock box is fine, but if you want to to hear it suckin in get a $60 K&N cone filter and change it out with your box. you will not run bad or need to be tuned if you buy the parts i just mentioned, but you will see no performance increase. you won't see a performance increase with any bov, and intakes probably will hurt your car if anything with no other mods. if you want performance i recommend you buy a boost controller and gauge first (~same $) or an exhaust setup ($200 more then you planned). both will make you much more happy.
I have the Injen system with the stock BOV. It works fine. As to if it is worth it or not, I think it was. However, there are some people on the board that will fight until they are blue in the face and call you a fool for upgrading from the stock airbox.
It looks nice in the engine bay, plus I got a little more hp. It was woth it to me.
Whats Up With All These Bov Threads! Its Like When Someone Buys An Evo The First Thing They Do Is Look Up Which Bov And Exhaust Sound The Coolest Rather Than Which One Is Functionally The Best
