After market Dampner pulley?
Old Feb 19, 2006 | 03:00 AM
trinydex's Avatar
so this unit is not lighter either?
Old Feb 19, 2006 | 09:33 AM
WillEatUrSTi's Avatar
So if this is not any lighter and/or smaller in diameter it's basically there because it cancels out vibrations even better than the stock pulley so you guys can run the motor up to a higher rpm?
Old Feb 19, 2006 | 09:16 PM
isal's Avatar
this is true . I have use before for my supra 2JZ engine . the ati damper so good . you can not compare to lighter pulley one . it's different . if you try you will know also . I try to order this damper for my evo 8 also .
