how much boost on built head and stock turbo?
Old Oct 20, 2005 | 12:23 AM
Derek888's Avatar
I just got my car tuned...well not completely tuned just a safe tune. I have a built head, stock 2.0 bottom and stock turbo running 93 octane. Whats the max boost I can go without any harm? I know 21psi is about right on the stock turbo but since I have a built race head I was hoping I can turn it up a bit
BTW will turning up the boost mess up my tune?
Old Oct 20, 2005 | 06:20 AM
Derek888's Avatar
bump
Old Sep 24, 2009 | 02:32 AM
MR. EVO MR's Avatar
23
Old Sep 24, 2009 | 07:26 AM
justa4banger's Avatar
You can run 30psi if you get a good tuner and your using 93oct.....
Old Sep 24, 2009 | 07:40 AM
tweaker41's Avatar
You will require a re-tune after turning up the boost. I'm on stock head/block minus cams/ARP Head Studs. I ran 24.5psi for around 1.5yrs on stock turbo. Added meth about a month ago and now I'm running 27.7lbs.
Old Sep 24, 2009 | 07:42 AM
Lancerguy'03's Avatar
im running 32psi with stock head and block.....w/ the Green....no problems...
Old Sep 24, 2009 | 08:49 AM
sprx19's Avatar
Bringing them back from the dead one thread at a time......
Old Sep 24, 2009 | 09:01 AM
okevolutionVIII's Avatar
True, look at Derek888's sig, I think he know what he's doing now days.
Old Sep 24, 2009 | 09:06 AM
Spoolin' By U's Avatar
Having a built head does not mean that you can automatically start running higher boost
pressures safely. Since you're still on the stock bottom end, I would say no more
than in between 27-29psi and thats with a safe and conservative tune. There is a point on the stock turbo in which overspinning it results in nothing more than diminishing returns on overall boost, unless you're injecting methanol into the mix, which has a cooling effect all its own.
Plus if you are still running the factory ignition coils swap them out for either the Okada projects or a full on COP system from Sparktech,Inc. and of course the spark plug gaps with need to be reduced down to .022 as well to prevent missfires and or spark blow out.
Old Sep 25, 2009 | 01:39 PM
MR. EVO MR's Avatar
i didnt look at the date but i did notice his post count and a built engine in his sig, i was saying to myself wtf he needs to know this so bad??
sorry
Old Sep 25, 2009 | 01:45 PM
tweaker41's Avatar
.022 gap on a factory ignition. On the SparkTech NonCDI I'm running .028 with zero issues at 27.7lbs of boost on stock IX turbo
Old Sep 25, 2009 | 10:07 PM
sparky's Avatar
In Taipei, is that 93 octane R.O.N.(Research Octane Number) pump gasoline? Is that the highest octane pump gas that you can get in your country? This would be have a lower octane rating than the 93 0ctane R+M/2 pump gasoline available in most areas of the U.S.
guswaym
Feb 24, 2012 12:40 PM
nismo n9ne
Jul 17, 2010 05:45 PM
Brandon03Evo
May 11, 2010 06:03 PM
Ianx
Oct 31, 2008 09:19 AM
fastassfourdoor
Aug 5, 2007 11:16 AM
