View Poll Results: Has anyone partially blown a head gasket with ARP head studs?
yes
11.11%
no
88.89%
Voters: 9. You may not vote on this poll
Head gasket apperad to went bad with ARP head studs
Old Oct 20, 2005 | 08:40 AM
GOKOU's Avatar
Originally Posted by TampaTurbo
It was done using a torque wrench. I was there. Its all good. just trying to figure why its leaking.
I wasn't talking about the nut. I was referring to the the stud. When you guys put the stud into the block did you tighten it by hand using an allen wrench? If so you need to use a rachet instead. Get one of the socket that have an allen wrench tip and use that with a rachet to tighten the stud down.
Good luck.
Old Oct 20, 2005 | 08:42 AM
TampaTurbo's Avatar
Originally Posted by gt40
Something was done wrong in the install. ARP studs are a lot stronger than stock and the only reason you would have a problem is because of the studs not being fully seated, torqued etc.
VTECH8TR did do it correctly and even in a star like pattern so there was equal pressure.
Old Oct 20, 2005 | 08:44 AM
TampaTurbo's Avatar
Good luck.
Thats what we did. VTECH8TR has the Fast and Furious garage set up. He's got everything.
Old Oct 20, 2005 | 08:52 AM
VTECH8TR's Avatar
Good luck.
Yeah i used the allen wrench on the ratchet instead of a hand one.
Old Oct 20, 2005 | 11:04 AM
EvoTech's Avatar
Oil weeping from the head and a blown head gasket are two different things! If you have bad compression then you can call it a blown head gasket. Mine weeps oil also after the 1x1 head stud intall. In retrospect it was not the right way to do it.
Old Oct 20, 2005 | 11:31 AM
TampaTurbo's Avatar
What exactly do you mean by a 1X1 head stud install. Sorry for the retardedness.
Old Oct 20, 2005 | 11:49 AM
VTECH8TR's Avatar
Mark,
He means 1 stock bolt off and 1 ARP stud back on for all 10 of them.
Old Oct 20, 2005 | 12:19 PM
TampaTurbo's Avatar
Originally Posted by VTECH8TR
Mark,
Oh Ok gotcha. Thanks. When can we do the fluids transfer and retorque? Thanks man.
Old Oct 20, 2005 | 04:44 PM
Az3ar's Avatar
I have the same problem and I am going to replace my head gasket in few weeks. I am using stock head gasket as its pretty thick and maybe going back to stock headstuds...
all the bla bla about head studs was for nothing...
Mine were installed by dyno4mance
Sheasta
Oct 29, 2015 05:00 PM
EVO 4 life
Oct 26, 2015 08:11 PM
jid2
23
Oct 3, 2009 05:38 PM
riceball777
43
Oct 12, 2008 08:26 PM
Smogrunner
15
Aug 12, 2004 08:06 AM
